Thanks, it's ok to not change anything (despite I think that a small minimum heat exchanger area would be better, to balance the impossibility to rotate it): the important thing is to know it in advance.
For next year, there are some things that I hope will be implemented:
1) 2nd order scheme
2) Slightly better mesh (I don't mean more layers, but a more accurate snapping)
3) Possibility to use heavier (more accurate) stls
4) Rotated heat exchangers (not "rotating"). It would be enough to have a discrete number of orientations: normal to the flow, 30° with respect to the ground OR to the simmetry plane. This would make the coding a bit easier.
5) Brake cooling ducts
