Yap, that is most likely hereME4ME wrote:Looks to me like a foam tub. The guy in black looks to hold a vacuum cleaner. They'll probably make cut-outs for Stoffel's arms so he can rotate the steering wheel, as well as costumize the leg padding. Real tub will be finalized once they're happy with the dimensions of the foam tub.
Tabloids in this forum are allowed?Joseki wrote:I was told Fernando tried the car on the simulator yesterday and he expected a better car
Really? Sorry but I consider this a total bullshit, a total bullshit. Some people see a post on Instagram of Fernando in front of the simulator room yesterday and right away ''sources'' say he does not like the car or he expected more.Joseki wrote:I was told Fernando tried the car on the simulator yesterday and he expected a better car
Okey, if you trust the source that's fine but I still don't buy it.Joseki wrote:I know the source and it's reliable (since it's the same source that said after Silverstone that the MP4-31 had rear suspension problems), so I kinda trust it. They are still simulating with the 2016 Honda unit and with a not final aero spec tho.
If the source is credible then why not giving it here? Also bauc and Paul are correct. What can you know from an early sim test, with completely new regs and no idea what other teams are doing?Joseki wrote:I know the source and it's reliable (since it's the same source that said after Silverstone that the MP4-31 had rear suspension problems), so I kinda trust it. They are still simulating with the 2016 Honda unit and with a not final aero spec tho.
Exactly true, as there is no reference to compare with.ALO_Power wrote:If the source is credible then why not giving it here? Also bauc and Paul are correct. What can you know from an early sim test, with completely new regs and no idea what other teams are doing?Joseki wrote:I know the source and it's reliable (since it's the same source that said after Silverstone that the MP4-31 had rear suspension problems), so I kinda trust it. They are still simulating with the 2016 Honda unit and with a not final aero spec tho.
Also, the rear suspension thing was quite obvious wasn't it? I think it was well "claimed" from early on. (Monaco for example)
Yes, if your source is credible give us his name, title and home address!Joseki wrote:I'm just a messenger guys, I'm not saying it's the factual reality for sure at 100%.
Also I don't want to ruin a friendship by spoiling "my source".
Nobody is ever "just" a messenger. You decided by yourself that the information was credible, and relevant for this forum, since you decided to post it.Joseki wrote:I'm just a messenger guys, I'm not saying it's the factual reality for sure at 100%.
