Nope, Ferrari.Juzh wrote:Supposedly inquired by mercedes.
I wonder what they're doing in that zone. The A-A section is the front of the monocoque/safety cell, spec'd as 300mm x 275mm.FrukostScones wrote:Merc has enquired aboout RB front bulkhead AA section:
https://translate.google.com/translate? ... rl&act=url
RB might be illegal but the matter will be dicussed in Febrauray to find a definite answer for 2018 cars ...
no one is going to change their tubs for 2017, it will be discussed for 2018 develoment if I understood correctly.SiLo wrote:Because they might not have noticed it until the off season when they will take a good look at everyone elses cars.
They noticed it didn't look right, then asked Charlie for clarification on it because it if gets ruled out, Red Bull have to make a change, and if not, they can copy it.
Well luckily you don't have to change the whole tub to change the suspension. It's just that they would probably want to themselves if they had to take off the trick suspension..FrukostScones wrote:no one is going to change their tubs for 2017, it will be discussed for 2018 develoment if I understood correctly.SiLo wrote:Because they might not have noticed it until the off season when they will take a good look at everyone elses cars.
at first CW didnt want to investigate, now it is to late as all tubs are signed off. So they look into the matter and see in Feb if the rule needs clarification regarding 2018. IIUC
whatRedNEO wrote:Well luckily you don't have to change the whole tub to change the suspension. It's just that they would probably want to themselves if they had to take off the trick suspension..FrukostScones wrote:no one is going to change their tubs for 2017, it will be discussed for 2018 develoment if I understood correctly.SiLo wrote:Because they might not have noticed it until the off season when they will take a good look at everyone elses cars.
Ok cool my mistake.FrukostScones wrote:whatRedNEO wrote:Well luckily you don't have to change the whole tub to change the suspension. It's just that they would probably want to themselves if they had to take off the trick suspension..FrukostScones wrote:
at first CW didnt want to investigate, now it is to late as all tubs are signed off. So they look into the matter and see in Feb if the rule needs clarification regarding 2018. IIUC![]()
different matter!!! (some misunderstanding going on, talking about AA section inquiry by Merc and not Fer. pseudo FRIC inquiry).
I don't think it's the new car, although the rear wing height seems to be 2017-spec.namao wrote:https://s29.postimg.org/796eftpuf/image.png
First pic of the new car. See the rear wing.
