What is mean is, it depends if Renault was already researching in 2015 for pu designs, which would be possible if the tokenrule was banned. Or did they only used resources to test improvements of the pu, limited by the tokenrule.roon wrote:What do you mean by your first sentence? 2015 somehow limiting 2016 open development in preparation for 2017.NL_Fer wrote:But it really depends on what the research team already has pre-cooked on the testbenches in 2015. The tokenrule was dropped almost beginning of 2016, they can develop some crazy stuff in a years time.
Maybe as of 2018 all PU will have about the same power output and efficiency. There are 2 brands creating an all new concept, Honda and Renault. You cannot expect that an all new design will have the same power output as the Mercedes.Vladimir wrote:And there is enough time for designing new car around that all new PU. In 2017. that will be crucial. All PU will have more or less the same power output. So chaise and reliability will play main part. Compare Red Bull and Renault F1 car in 2016.
Maybe I can't expect the same power, but they will have more power in 2017 PU, than in 2016 PU for sureVladimir wrote:Maybe as of 2018 all PU will have about the same power output and efficiency. There are 2 brands creating an all new concept, Honda and Renault. You cannot expect that an all new design will have the same power output as the Mercedes.
Yes the v8 was frozen again in 2009 but even still mercedes had unreleased potential in there engine freeze and that allowed them to continue adding hp with a frozen spec engine. Renault used there design to power the blown diffusers which the mercedes and ferrari engine was not designed to do. Hence why Red Bull was able to get the most of this ability in the later years of the v8 formula.NL_Fer wrote:In 2009 the v8 was equalized and frozen till the end. No natural maturing here.
Even v10 was being developed in 2005, after 10 years.
They let Renault have a solo upgrade to get closer in power because the other 2 were already near as dammit in power. That was their "equalization" . The only parameter was peak power within the new 18k rev limit.roon wrote:Equalized by what parameters? Not contesting you, just curious. In comparison to how the V6s are somewhat equalized as well, considering the specificity of their regulations.
at least in this v8 aera renault created something by themselves with fair competition to win with a bit less power, and wasn't ridicusly granted by fia token or freeze as mercedes was last 3 years to keep their "advantage " threating to quit F1 reducing to zero any competitioncarisi2k wrote:Yes the v8 was frozen again in 2009 but even still mercedes had unreleased potential in there engine freeze and that allowed them to continue adding hp with a frozen spec engine. Renault used there design to power the blown diffusers which the mercedes and ferrari engine was not designed to do. Hence why Red Bull was able to get the most of this ability in the later years of the v8 formula.NL_Fer wrote:In 2009 the v8 was equalized and frozen till the end. No natural maturing here.
Ferrari was allowed a "reliability" upgrade after their malaysian failure in 2010, gaining them 8 bhp.Pierce89 wrote:They let Renault have a solo upgrade to get closer in power because the other 2 were already near as dammit in power. That was their "equalization" . The only parameter was peak power within the new 18k rev limit.roon wrote:Equalized by what parameters? Not contesting you, just curious. In comparison to how the V6s are somewhat equalized as well, considering the specificity of their regulations.
Another reliability upgrade was a modification to the pneumatic valve return system, which allowed them to improve fuel efficiency - something that had become important when refuelling was banned.Juzh wrote:Ferrari was allowed a "reliability" upgrade after their malaysian failure in 2010, gaining them 8 bhp.Pierce89 wrote:They let Renault have a solo upgrade to get closer in power because the other 2 were already near as dammit in power. That was their "equalization" . The only parameter was peak power within the new 18k rev limit.roon wrote:Equalized by what parameters? Not contesting you, just curious. In comparison to how the V6s are somewhat equalized as well, considering the specificity of their regulations.
