Engine specificationPowerful and reliable, with an impressive noise like no other, the 750bhp engine is brand new and unique (to Superleague Formula) design comes in a V12 configuration and 4.2 litre capacity
No of Cylinders: 12
Capacity: 4.2 Litres
Configuration: 60 degrees V formation
Weight: 140KG (Dry)
Peak Power: 750bhp @ 11,750 rpm
Maximum RPM: 12,000
Peak Torque: 510 N/M 9,500 10,500
Its like a 1991 engine performance, with 0.7 litres more, don´t you think?
Having already passed all the latest safety crash tests, in accordance with the governing body’s (FIA) criteria...
Under-body aerodynamics will also allow cars to follow nose-to-tail, creating increased overtaking opportunities
jaja! seems these guys read this forum!‘Slick’ racing style tyres with no grooves or tread
PANOZ (USA) SUPERLEAGUE DP09B CAR SPECS
Overall car width to wheel rim: 2000mm
Wheelbase: 3156mm
Total Length: 4600mm (tbc)
Max Height: 995mm
Front Wing Width: 1400mm
Rear Wing Width: 1000mm
Bodywork Width: 1400mm
Weight Target: 675kg
this one looks sci-fi!
Its like this guys car:
