2017 F1 general testing thread
Anthropolyte
Anthropolyte
Re: 2017 F1 Pre-season testing February 27 - March 2/ March 7-10
Palmer up to third in the Renault! I know times don't matter at this point, but it inspires confidence that they may have sorted their engine issues.
Juzh
161
Gerhardsa wrote:
bonjon1979 wrote:That's the lap record gone. Well, actually, it's faster than the 2010 pole, I think massa did a quicker time at one point in testing. Interestingly, I don't think ferrari are out of touch with that time. They're only 1,8 away on the mediums so you'd have to think they'd get down there on the SS. I feel that Merc are still out in front but that Ferrari aren't too far off it.
Yeah, fastest in testing 2008 was 1.18.3 by Massa, so the unofficial quickest for this layout is still a bit away
He was on slick tires and thus far from obliging with the regs at the time, but yeah, outright record is outright record, no matter the circumstances. Though teams could in that case also just remove fuel flow limits for a few laps and go ballistic.
Felipe Massa was fastest on the first day, using slick tyres to set a 1’18.339, which proved to be the quickest time of the session. The following day he was quickest of those on grooved tyres, setting a 1’20.283.
I have to say i'm surprised by what Mercedes is doing, last year they never touched the SS(don't even mention the ultra), barely any short runs, a whole lot of mediums... and were still pretty much on pace.
Why the change?
marvin78
marvin78
That's wat Mercedes does since 2014: try to fool everyone. It's boring by the way.
FrukostScones
163
Sevach wrote:I have to say i'm surprised by what Mercedes is doing, last year they never touched the SS(don't even mention the ultra), barely any short runs, a whole lot of mediums... and were still pretty much on pace.
Why the change?
distraction
and or to learn about the new more durable compounds.
to establish the speed difference...?
bonjon1979
bonjon1979
30
Why the change?
Brand new tyres compounds, they've got to try and understand the whole range. Also, the weight distribution etc. everything has changed this year where as in 2016 they were dealing with more known quantities.
Gerhardsa
Why the change?
I was thinking the same thing.
Might be because of the construction of the tyres that changed. They might feel that this years soft or super soft equates to last years medium in terms of deg and wear?
Who knows.... :wtf:
bonjon1979 wrote:
PhillipM wrote:To be honest I'd be surprised if someone doesn't break into the 17's.
I don't think that's going to happen. It looks like the softest two compounds aren't quite lasting a lap around Barcelona which is a very high deg track.
There'll be a lot of setup for tyre life by then, given the wider rubber will be a little harder to manage geo-wise. And a lot more rubber down.
Gerhardsa
marvin78 wrote:That's wat Mercedes does since 2014: try to fool everyone. It's boring by the way.
They are not fooling anyone. Everyone knows they will be hard to beat.
So what if its boring. Its testing, not qualifying or race day!
Vasconia
Anthropolyte wrote:Palmer up to third in the Renault! I know times don't matter at this point, but it inspires confidence that they may have sorted their engine issues.
There is some relief in Renault because they have even posted a photo to celebrate it.
GPR-A duplicate2
64
Why the change?
If I can recall things correctly, the harder the compound was, the bigger the difference to the chasing pack and the softer the compound was, the closer the chasing pack became to Mercedes. On UltraSoft, the difference between Merc Pole and the chasing pack was almost negligible. As they based their car more on Mediums, probably that was the outcome. For majority of the season, it was the Soft rubber that was used. So, this time, they are basing their car on Softs and it's probably a good idea to have a reference towards SS and US as all their make is becoming different. That's my two cents.
CriXus
CriXus
95
Why the change?
Merc had problem with extracting the maximum of the reds and the purples, but as we have seen those tires are not usable in Barcelona. I am not sure how much usable information Merc can gather.
“The reasonable man adapts himself to the world: the unreasonable one persists in trying to adapt the world to himself. Therefore all progress depends on the unreasonable man.” - George Bernard Shaw
namao
namao
I saw that the MCL32 is 15 km/h slower in S1, 20 km/h slower in S2 and 15 km/h slower at finish line, than the other teams. Maybe the oil tank issue persists (high G-forces produces mechanical failures).
Why the change?
I also believe that with the tyres predicted to last much longer, it's better to always use the softest tyre opposed to a tyre which balance off peak performance with durability.
marvin78
marvin78
As you say it. It's boring, that they try to fool everyone ("Ferrari is hard to beat"... etc. from 2016) and that it is so obvious.
I know what testing is. That really is not the point.
