#aerogollumturbof1 wrote: YOU SHALL NOT......STALLLLL!!!
Due to the wider & taller diffuser and an increase in rake present on the 2017 cars, the surfaces of the brake ducts, diffuser, floor, suspension arms and rear tire sidewalls are now all in closer proximity to each other. Perhaps they have unified all these elements in a unique way.Xero wrote:Completely agree flmkane.
With regards to a basic looking floor, it's my view they are simply testing a base design in this new and different layout. Once they understand how the base works with the rest of the car, then they can start cutting slots and adding shapes to fine-tune the airflow where needed.
It may also be the case (which has been hinted by Eric Boullier) that they have something special yet to come in that area. He's been quoted several times suggesting that when other teams see it, they may lodge protests, but that they are convinced their innovation is legal. I can't see anything fitting that description yet, so it may be some sort of floor/diffuser design that they're holding close to their chests for now (less time to copy). Of course, it could be something else entirely.
That was for the suspension. I need source for this. Him saying those words.Xero wrote:Completely agree flmkane.
All i can see is a wet patch where he hits the gas pedal and rear snaps off which is logical. When Ferrari comes behind him he has exactly the same problem, but a little less of it due to the fact that he stepped on the gas pedal a little later.Enstone wrote:According to de la resta : ""The McLaren is more nervous than I expected," he told El Confidencial.
"I see a Fernando (Alonso) who has to work on the steering wheel more than is ideal. The car is unstable in turns 1 and 5 and tends to lock wheels.
"No one is attacking like Fernando. I really did not expect the McLaren to be as restless on these wide tyres," de la Rosa added."
http://www.grandprix.com/ns/ns35867.html
I agree we can say that she's struggling in some corners... take a look at : 11:33 and 11:54
https://www.youtube.com/watch?v=G4TucdgMPj4
The fact is that the car isn't struggling on the wet part... but on the dry one !proteus wrote:All i can see is a wet patch where he hits the gas pedal and rear snaps off which is logical. When Ferrari comes behind him he has exactly the same problem, but a little less of it due to the fact that he stepped on the gas pedal a little later.Enstone wrote:According to de la resta : ""The McLaren is more nervous than I expected," he told El Confidencial.
Redbull had no problem at all, as the driver went into the corner slower and not in such an angle, acceleration was softer as well.
Atleast to me it looks as a wet patch issue, or an engine mapping needing a fine tuning.
