McLaren MCL32 Honda
harjan
harjan
Re: McLaren MCL32 Honda
How much of the rigidity comes from the floor? In other words; if the floor isn't offering enough rigidity, could this in turn place more torsion etc on the PU/drivetrain structure? Or would it work the other way around- the PU is flexing and causes this to twist the floor?
ema00
ema00
another engine failure?
i70q7m7ghw
i70q7m7ghw
49
harjan wrote:How much of the rigidity comes from the floor? In other words; if the floor isn't offering enough rigidity, could this in turn place more torsion etc on the PU/drivetrain structure? Or would it work the other way around- the PU is flexing and causes this to twist the floor?
I would have thought very little, most of the rigidity would come from the monocoque and drivetrain.
Goran2812
Goran2812
27
Car looked a bit better towards the end of the morning session. He took turn 1 with more speed and agression I did not see any twiching or problems...
Visit my photo page! -> http://www.gorankphoto.com/formula1
BosF1
BosF1
Nice pics!
Jef Patat
Jef Patat
Amazing how that flow is going down just in front of the sidepod opening. :wtf:
BosF1
BosF1
The second picture shows the extra inlet inside the intake very well.
What is that "bulge" underneath the sidepod inlet behind the bargeboard on the floor ??
BosF1
BosF1
All flow coming from the front suspension is directed downwards. It think it's directed to go towards the undercut of the sidepod, although the green flow viz didn't reach that far (or at least not that we can see).
Jef Patat wrote:Amazing how that flow is going down just in front of the sidepod opening. :wtf:
What else would you expect to happen in front of a high pressure area such as sidepod intake? :D It's a lovely shot, showing even both stagnation points (top and bottom) and also that bottom one could be even a bit more inside the intake at full speed.
BosF1 wrote:All flow coming from the front suspension is directed downwards. It think it's directed to go towards the undercut of the sidepod, although the green flow viz didn't reach that far (or at least not that we can see).
Towards the undercut and (under) the floor as well. All top teams are doing it (probably others as well), using wishbone pick-up points, various canards, winglets and what not...
Jef Patat
Jef Patat
I wasn't expecting all flow below the upper stagnation point to go downwards, I would have expected a bigger part of it to go upwards.
The bargeboards help that as they're turning the flow outwards just in front of the undercut
GoranF1
GoranF1
151
