Stop sorry, That was wrong on my part. Should have said it more precisely. They planned to carry 10Kg ballast for balancing the car. That has been reduced by the approximately 10KG heavier Merv drive train. They told the drivers to lose 2Kg until MelbourneSamraj_official wrote:so does that mean force india weighs 738kg rather than 728kg???? and the car looks sluggish in the corners too!!!!! Bad way to start the season.McMrocks wrote:An Article from AMuS quoting Bob Fernley and Andy Green
Things they actually said:
-Bob Fernley: Ferrari is 1.5 sec faster on the long runs
Williams is faster too but they expect to catch up during the season
-Andy Green: car is 10Kg too heavy
Merc engine got heavier
Merc gearbox got heavier ("12cm longer" plus changes to pass the rear crash test)
Windtunnel data does not corellate 100% to the track data
Things the article says without quoting somebody
-Force India will not do Qualification runs in Barcelona
- Force India struggles with cracks in the exhaust tail pipes
- Merc gearbox's rear section is very high and requires the rear wing pylon going through the exhaust
-they plan to tighten the sidepods (as they dont need that much cooling)
My opinion: From the picture it looks like the gear box housing isnt that high
i also thought the track correlation data would be great since they started using 60% TMG Windtunnel.
