As everyone is speaking about the increased lateral forces that F1 cars will be achieving this year, I believe that it is also interesting to note that the braking power will be also increased up to a extent where teams as drivers will be reaching new limits.
From now there have been some figures saying that about 25% more braking torque is expected (https://www.motorsport.com/f1/news/anal ... nt-869021/)
Also the rules are accounting now for this by increasing the maximum brake disc width to 32mm (it was 28mm). Even if the maximum diameter is 278mm, we have all seen differences front/rear in the brake last year: does anyone have an indication on the current diameter?Brembo: "The level of grip is higher so you can basically transmit more force in a shorter time under braking. That results in the peak of braking torque – and we are predicting a 25 percent jump."
Also, and maybe for everyone´s general interest, do you know an approximate figure of the disc inner diameter?
Let´s see where does all this lead to, already now we have Haas complaining about braking issues...
