ReoPTy
ReoPTy
-34
Re: Renault V6 Power Unit
Renault has some MGU K issues with thier second generation ERS system , insulation !
hope they fix it soon
Vladimir
Vladimir
-1
Remi Tafin said, that problem was noticed in development stage on dyno, and solutions are on the way before Melbourne. All teams are very confident, reliability will be sorted.
gandharva
gandharva
252
The MGU-K shaft broke down several times. A stronger shaft is already in construction. I'm more worried about the turbo problems RBR had on last day of testing. Hopefully this is not something fundamental...
63l8qrrfy6
63l8qrrfy6
368
gandharva wrote:The MGU-K shaft broke down several times. A stronger shaft is already in construction. I'm more worried about the turbo problems RBR had on last day of testing. Hopefully this is not something fundamental...
source ?
gandharva
gandharva
252
Godius
186
Some interesting sound comparison video's of practice starts from the Barcelona grandstand:
Renault (RBR):
Renault (RBR), Ferrari (Ferrari & Haas) & Mercedes
Juzh
161
Godius wrote:Some interesting sound comparison video's of practice starts from the Barcelona grandstand:
Renault (RBR):
https://www.youtube.com/watch?v=63CD1X6pu1Y
https://www.youtube.com/watch?v=E04VXt-7PE4
What's with the sudden tone change on the renault engines after the first few gears?
at 41s in the first clip and 42s in the second.
toraabe
toraabe
The Mercedes engine has much more low end grunt than the others. Interesting... Pure superior drivability.
hurril
hurril
Renault (RBR):
It has been speculated earlier that that is from opening the wastegates.
Juzh
161
hurril wrote:
Renault (RBR):
Thanks. That does make sense.
r101
r101
Abiteboul: Engine exceeding power targets, but reliability is in question:
https://www.motorsport.com/f1/news/rena ... ts-882373/
flexcon
flexcon
So with that in mind, is this a way of controlling sudden wheel spin out of corners? When you listen to the Honda and ferrari, and the Merc( although low volume) they are all sounding like some sort of cylinder shutoff is occurring coming down the gears and off throttle.
The renault engine, is smooth. Nothing. Nada. Nat a single babble from that engine. But then coming out of the corner, sounds like bloody vTec kicking in with the possible waste gate opening.
EDIt here is a video I took at testing.
Pierce89
60
Sounds more to me like they're just going full throttle after they click up to 2nd.
63l8qrrfy6
63l8qrrfy6
368
It sounds to me a lot like they have a quill shaft on the MGUK and it's breaking.
3jawchuck
3jawchuck
37
What makes you think this specifically?
