Re: Honda Power Unit
I wonder if for the next race they could band aid the issue with some carbon supports/stays to the headboxes and crankcase? Depends if they can have a reshuffle to make room I suppose but it should help whilst it's fixed properly.
dren
227
Take away one of the center pistons in both banks and you could use something like this for a short crank. Then have the MGUK coaxial with the crank.
Honda!
fausto cedros
glenntws wrote:
24 Mar 2017, 21:45
Well, the noises we hear is probably a engine mapping which reacts to upshifting by creating short intervals of "25%-100%" throttle until the engine shake is lowered. At least that's how it sound
Hey Glenn, sorry to bother you again, but i guess that if your hypotesis is correct that will clearly show as some kind of flat zones in the speed versus distance charts, especially at high speeds. I didn´t have the chance to see much of the fp´s today, but if it´s real maybe a close look to the progression of the real time speed shown sometimes by the tv coverage when shifting to the higher gears, or a video analisys (advance of the car vs frames per second) would suggest something. What´s your idea? Did skyTV show anything? Could instead be the noise of some torsional mass damper/flywheel of some kind set up to mitigate the occurrence? Goodnight, let´s see what tomorow brings.
"Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere" Anthony Bruce Colin Chapman
Singabule
Singabule
glenntws wrote:
24 Mar 2017, 21:45
Well, the noises we hear is probably a engine mapping which reacts to upshifting by creating short intervals of "25%-100%" throttle until the engine shake is lowered. At least that's how it sounds like to me.
The question is why they do that. And the answer has to be in the fact, that the new engine is incredibly lightly built and together with a gearbox structure which has the potential to pass the forces happening at upshift to the engine and induce a harmonic > results in extremly hazardous shaking.
Now, Honda obviously uses something like a oscillating load control to counteract against the vibrations happening. They don't use cylinder shutoff to counteract, because they want all six cylinders working to have a "controllable" and most vibrationless running as possible, that's why the oscillate with the loading.
Now, what can they do against that? Certainly, a good point for change is the gearbox housing, they could redesign the structure a bit but that is a pain in the a** to do so because it affects most mechanical parts of the rear-end. Another possible point is the engine (the way they obviously go), where they could implement some struts or a light block and/or head changing to prevent the creation of a harmonic with the engine.
This all explains the lower speed they have, because the maybe have 0.5 seconds per straight, where they don't run on full throttle. Without that, they would definetly be MUCH closer to MB. And with much, I do mean > very close!
This is all my theory. If I have time left, I could try something like a audio analysis but when it comes to this area, it's getting hard to "read the signs" :D
This is what i expect from you glenntws, good job. Yes, absolutely right. Remember cosworth in beginning of v8 engine always doing this, their gearbox cannot handle the vibration shoot for upshift and downshift. This also protect their engine from cracking caused by vibration and sudden rpm drop. They solve the problem by redesign their crank.
Singabule
Singabule
Wazari wrote:
24 Mar 2017, 22:11
Disclaimer: The following is fictional and should be read for entertainment purposes only. Any similarities to facts or actual people should be considered purely coincidental. Ok, got that out of the way on the advice of legal counsel.
Well, Friday was officially my last day at HRD. I decided to leave and go back to retirement for many personal reasons. This has nothing to do with my feelings towards Honda. They have been extremely good to me and some of my most enjoyable times in the 40 plus years in the automotive industry have been at Honda Motors. This will be my last post in this forum. I will visit from time to time and for those of you who have my personal email, please feel free to contact me there. I think it’s time to move on and focus on my personal projects that I have neglected in the recent years. Some of you may be wondering why someone like me would be posting here. Well this forum has been a diversion, entertainment and therapy for me. I have had some very difficult mental struggles over the past 18 months and this forum has been a tremendous escape and relief for me though some difficult times. Thank you for many of your kind words and thank you to the haters as you too have given me many a laugh. Being called spineless, clueless, a fraud, idiot, uneducated, etc., has brought me a lot more smiles than anger. If you don’t have thick skin then you don’t belong in F1.
Here’s a recap of my experiences including material based on documents, meetings and conversations with fellow HRD personnel including my nephew.
I was quite surprised when my nephew told me during New Year’s 2013 that Honda was going back into F1. It takes numerous resources and lots of money. I couldn’t understand why Honda would spend hundreds of millions of dollars for this but yet part of me was excited. I figured Honda would enter in the 2017 season based on the new formula proposed for 2014 and the amount of time it takes for R and D to produce a “new concept” PU. And then later when I heard that they were going to supply McLaren starting in 2015 I was quite shocked. There is word 無理 which I think is a very difficult word to translate correctly but it seems Honda forget the meaning and concept of that word. To put together a PU of this complexity in 20 months when others had 48 to 60 months to develop this formula PU seemed like a daunting task. Furthermore with this new token system and PU number restriction, well this was not going to be good no matter how you looked at it.
Then I learned that McLaren had set parameters for an overall packaging requirement. In the past it’s always been my experience in F1, you built the engine and then the bodywork around it. Apparently this time it was going to be the other way around. I blame Honda 100% for accepting this methodology. There were four proposed layouts I discovered for the new PU. Two were based on turbine and compressor both at rear and two with a turbine and compressor on top and in the “V”. Only one fit the proposed requirements and apparently there was no negotiating at this point. Many things were said about how there was no “Size zero” requirement and Honda took it upon themselves to make the packaging as small as possible. Well it really wasn’t quite that simple. For 2016, it’s easy to say that the requirement is no longer needed when wholesale changes can’t be made between 2015 and 2016 because of the token system. But again, I blame Honda 100% for agreeing to this concept knowing that success was going to be impossible in that short a timeframe and with a much compromised layout design. 2016 was trying to make the best of a compromised situation from the start. Hard to win the Kentucky Derby with a 3 legged horse.
I started working with a team dedicated to the 2017 PU back in the spring of last year. I had hopes that some of the concepts could be introduced in 2016 but that did not happen. Lack of time for development and testing made it impossible for an upgrade that I was hoping could be introduced in Malaysia. So it was tabled for 2017. We knew that the previous layout was not a winning combination and as time went on there was no way it ever could be. A major layout change was needed and both Honda and McLaren moved forward making wholesale changes. This in my opinion should have been the PU introduced in 2015. So in essence in my opinion, another 18 months behind. So in that aspect I am extremely proud of what Honda has accomplished in that short amount of time. On the dyno this year’s PU has shown very impressive numbers; better than I ever expected. Reliability is a big issue with so many new, “untested” components. At the end of day, I believe the new PU is a diamond in the rough. New combustion process, completely new layout including block, pistons, crankshaft, rods, pistons, new ERS, new MGU-H etc. It’s all new. There’s going to be a lot of teething pains but in my opinion the only way to beat Mercedes. Obviously they are the benchmark and so far Ferrari, Renault and Honda all have failed in their PU’s compared to them. Honda with the biggest amount of “catching up” to do. How much time will it take? I think realistically 4 to 6 months to resolve the reliability issues. Including one major one that I have mentioned to some of you after the first week of testing, the cylinder head. The PU is a highly stressed component of the chassis and I believe the method of components being attached to the upper portion of the engine including the heads needs to be readdressed.
Honda has made a accomplishment given the timeframe. So that is my take. I am so very proud of HRD no matter what anyone may say. We are not clueless nor a bunch of idiots. Flawed yes, stubborn yes, competitive yes, with a very strong with to win. Honda is not doing this for fun or as a research exercise, they’re in it to win it. That I know for sure. Will they? Time will tell….. The relationship between McLaren and Honda can vastly be improved in my opinion. Kaeru-san needs to go. My dream…..a WCC for Williams Honda in 2019.
Mitsuru
It is always Hard to say goodbye, especially you are the reason i always reading this website. Thank you for inspiring uneducated person like us. Hope you enjoy your retirement. Williams honda, i would change my preference from MCL to Williams if that happen, especially they have very strong leader and maybe that is what honda need to win in F1. Mr B is not right person I think. RD is, but he is kicked.
Who is this amphibious person? :lol:
Singabule
Singabule
godlameroso wrote:
25 Mar 2017, 01:34
It is me.. :lol: I used to be merc fans as engine supplier and i never put emphasis to constructor. However, i love to see someone put hard effort to out from their problem, and that is why i enjoy honda forum so much.
Kaeru = frog, who is froggy? :lol: There's 2 Mr B's in McLaren, as irritating as the one in the pit wall can be, he does keep the ship moving. McLaren is still a hugely popular team, mostly because people want to see Alonso win, and because they want to see McLaren Honda succeed. What a story turning the team around would be, that's why I think now more than ever Honda and McLaren have to resolve their differences and work together. This all can still be salvaged, I genuinely believe they can overtake at least Ferrari and Renault this year.
RicME85
52
GoranF1 wrote:
Jef Patat wrote:
24 Mar 2017, 21:41
GoranF1 wrote:
24 Mar 2017, 19:29
There are definite signs of improvment....if it is true than Mario Ilien is working in Milton Keynes next upgrade engine might be very good.
Sorry, I don't understand Milton Keynes (Red Bull), Mario Ilien (helping out Renault if I recall correctly). Has he moved to Honda?
I heard a unconfirmed rumor he has left Renault for Honda and works at Honda's MK base as advisor.
He has definitely left Renault
mkiiw
mkiiw
Wazari wrote:
24 Mar 2017, 22:11
Mitsuru
Wazari, salutes for all of your contribution, myself as a amateur fan boy on car technology. It is always exciting to read and learn your post . All the best for retirement life . You are 勇者 to join the battlefield again of f1 in 2016 with HRD 武士, it is just the timing and maclaren setup (demands) are not helping the project. I am waiting for you guys to polish the diamond to shine.
Once again salutes to Wazari
=D> =D>
Singabule
Singabule
godlameroso wrote:
25 Mar 2017, 01:51
So Ferrari and renault in the same level? No way. Renault should be overtaken after 3 races :lol: Mr. B-mouth Boullier offcourse, but the others not to well documented, but i smell fishy in motorsport and autosport :twisted: I hate someone whose throw his problem to other person.
Renault will catch up to Ferrari soon if Ferrari doesn't mind it's task, or at least Red Bull will. Honda is making tremendous progress, these things can develop in strange ways, little bits here, little bits there, then suddenly all the little bits start adding up and have a snowball effect. Sometimes all it takes is just two or three critical pieces to be solved and it makes the rest of the puzzle obvious.
Singabule
Singabule
Back to engine topic, where is mguh cooler? Any clue? Left or right sidepod or in engine radiator itself?
ncassi22
ncassi22
31
Posted mainly for the pictures - the content is very much a rehash of current speculation.
https://twitter.com/ScarbsTech/status/8 ... 0689805312
Singabule
Singabule
Certainly their engine is not that bad in qualy
