ENGINE TUNER wrote: ↑28 Mar 2017, 00:40
godlameroso wrote: ↑28 Mar 2017, 00:27
There's also piston height itself, a thinner piston let's you use a longer rod, for the same throw, increasing the rod ratio.
We all know that these huge multinationals have long since have had programs that simulate and optimize most of these minor variables.
This character does not have the slightest idea, I do not understand why he can put negative points an ignorant, to which a variation in diameter is a cylinder of 0,2mm (80mm +/- 0,1mm) it seems that it is not significant (0,125%) And he orders me to read the regulations.
Power unit dimensions :
5.3.1 Cylinder bore diameter must be 80mm (+/- 0.1mm).
5.3.2 The crankshaft centre line must lie on the car centre line and 90mm (+/-0.5mm) above the
reference plane. The power unit may only transmit torque to the gearbox by means of a single
output shaft that must be co-axial with the crankshaft. The output shaft must rotate clockwise
when viewed from the front of the car.
5.3.3 Valve stem diameter must not be less than 4.95mm.
5.3.4 The crankshaft main bearing journal diameter (measured on the crankshaft) must not be less
than 43.95 mm.
5.3.5 The crankshaft crank pin bearing journal diameter (measured on the crankshaft) must not be
less than 37.95mm.
5.3.6 No cylinder of the engine may have a geometric compression ratio higher than 18.0.
For this the mm are not important, he does it to spans.
In the majority is defined a minimum of dimensions, forbid to make it bigger?
