Renault Sport F1 R.S.17
mikhak
mikhak
Re: Renault Sport F1 R.S.17
matt21 wrote:
Thunders wrote:There is the now legal RW Pylon:
https://imgr2.auto-motor-und-sport.de/N ... 042649.jpg
Does this make any difference? And if yes, what is the benefit of the original Renault solution.
For me it doesn´t really matter, and as a designer I wouldn´t put too much of effort there.
There would be no structural benefit of the original design. It's just for aerodynamic reasons. You will always get some losses at the junction where the pillars meet the rear wing. Structurally it was best to attach the pillar to the rear wing suction side as we've seem in many seasons previously. But the flow tends not to be so healthy around the junction and leads to earlier separation on a critical wing. So the designs started to migrate to attachments on the pressure side. However still you will get losses sent to the suction side of the flap. Following the design trend by moving the junction even higher you send the losses over the pressure side of the flap so cleaner flow on the flap and less likely to separate. The aero effect is likely not huge but then we see lots of little details on F1 cars where the effects will be small!
Enstone
Enstone
30
Is that a 3rd shock absorber ?
scarbs
scarbs
393
4th... two side dampers, roll damper (diagonally mounted), heave damper (missing from horizontal position)
Enstone
Enstone
30
scarbs wrote:
23 Mar 2017, 20:15
:shock: is there any team who has used the same configuration and also 4 or even 5 dampers ?! :mrgreen:
Via AMuS
Enstone
Enstone
30
By scarbstech
seezung
seezung
56
Vladimir
Vladimir
-1
That cobra air intake looks so good and seems that aerodinamicaly functioning like some deflector for improve the flow in rear.
BanMeToo
BanMeToo
Why three sets of paddles? Only one paddle is allowed for the clutch this year, correct?
CLKGTR
CLKGTR
101
Enstone
Enstone
30
Seems like Renault have dedicated a lot amount of time, to work on/search an unique solution for the rear wing... that's maybe why they don't had enough time to developp a t-wing or some other aero stuff arround the car or under the nose :mrgreen:
ScrewCaptain27
577
Via AMuS:
- Serj Tankian
Enstone
Enstone
30
It's just me or the shark fin is different and more agressive :
everythingisawesome
everythingisawesome
Enstone wrote:
15 Apr 2017, 20:09
http://media.f1i.com/wp-content/uploads ... AAOpcA.jpg
https://www.renaultsport.com/local/cach ... 1492193562
No, they are exactly the same
