Question relating to overtaking and the current ground-effects / downforce configurations.
It seems that in race conditions, you can watch cars on the main straight braking and entering the first corner with a minimum of sparks flying. Understood that the sparks are from the rub-blocks on the underside and that they effectively become the ride height control. Must feel nasty inside the car.
What doesn't make sense is that when a driver is defending against an overtake and the attacking driver is pushing things to the limit .... there are sparks everywhere, from both cars. This is both cars braking at the limit and DRS disabled. Without some form of ride-height control, this shouldn't happen, or does it.?
The only explanation, assuming that there is no ride height input from the driver, seems to relate to brake induced squat at the rear, the front or both and that in the heat of the battle, the braking forces (and effort) are higher than when not in a passing situation. Any suggestions.?
Inquiring minds need to know.
