Williams FW40 Mercedes
LookBackTime
LookBackTime
472
Re: Williams FW40 Mercedes
Engine cover is slightly different with a bigger exit hole(very small increase compared to what was needed last year).
Also Massa with just one T wing.
LookBackTime
LookBackTime
472
Lance is using the old FW!
During the night session this bigger body wasn't needed.
LookBackTime
LookBackTime
472
LookBackTime
LookBackTime
472
LookBackTime
LookBackTime
472
LookBackTime
LookBackTime
472
LookBackTime
LookBackTime
472
This image is the most interesting!
The density of Kiel probes are higher in the upper side of the frame.
So the aero team is looking for more detail info in that area!
from Wikipedia!
A Kiel probe is a device for measuring stagnation pressure or stagnation temperature in fluid dynamics. It is a variation of a Pitot probe where the inlet is protected by a "shroud" or a "shield." Compared to the Pitot probe, it is less sensitive to changes in yaw angle, and is therefore useful when the probe's alignment with the flow direction is variable or imprecise.
LookBackTime
LookBackTime
472
One additional comment from my side: looks like the rack with Kiel probes has a much better build quality.
It is build with better attention to details.
LookBackTime
LookBackTime
472
Williams is using hot/very hot air to keep disk brakes in the right temperature zone!
LookBackTime
LookBackTime
472
LookBackTime
LookBackTime
472
