It's preseason and a good time to chew over some general ideas to improve F1. I think all motor racing fans want to see close wheel to wheel racing. I don't see any proposals that are going to acheive this in the next couple of years in F1.
What ideas are out there for improving the ability of cars to overtake each other on the track? We have heard about the research funded by some of the teams, that is looking in to aerodynamic changes that could improve the ability of cars to follow each other through fast corners but I haven't heard anything recently. The FIA highlighted the possibility of a radical twin rear wing design, one over each wheel, to reduce the turbulent air in a car's wake. Has this idea died a death?
I suspect there is a limit to the amount of downforce that can be generated by one car closely following another purely by trying to smooth the flow off the back of the leading car. This limit must in a large part be due to the fact that the lead car is generating downforce for itself and therefore by the time the air reaches the following car it has already done a large amount of work, making it harder to generate additional downforce. Does anyone have a better explanation of this effect that is accessible to us lay-people, it would be appreciated! Anyway what I'm trying to say is that while F1 cars generate such a large percentage of their grip through downforce, no amount of smoothing of the exiting airflow will help cars follow closely through fast corners.
Okay, we all know that the FIA should bring back wide slicks and reduce the influence of aero packages to redress the balance of mechanical grip to aero (CHAMP cars are trying this for 2007, did it work? - http://www.champcarworldseries.com/News ... p?ID=10684). But if F1 cars are to remain the exotic looking machines we so love then aerodynamics will always have their place and the following car will always find it difficult to line itself up for that pass at the next corner. I propose some measure to counter this disadvantage.
I'm not sure my proposal is technically feasible but bear with me, I think it has some attractive qualities (if they can create self healing rubber then there is some hope - http://news.bbc.co.uk/1/hi/sci/tech/7254939.stm). At present the track rubbers in as the race progresses, improving grip on the racing line. What if (okay a big if, I did warn you) the tyres laid down a volatile compound that dramatically improves grip on the track for a few seconds before evaporating. The driver in front would then have to put in some hot laps to build a gap to the driver behind to break the advantage the other has in following closely. If he can't he will present overtaking opportunities and if overtaken the positions will be reversed and the onus will be on the new leader to try and defend his position. We could even have a situation where cars further down the track benefit from all the cars in front laying down this volatile compound, allowing them to keep pace with the front runners for longer and not produce such a disjointed field early on in the race. It would certainly make back markers less of a problem!
I'm not suggesting that we should turn racing on its head. The lead driver has the advantage of track position, is still creating an aerodynamic penalty for the car close behind, but we could 'tune' the boost in mechanical grip given by this volatile compound being laid on the track, to at least partially cancel out the aerodynamic penalty. I feel quite strongly that we shouldn't lose touch with the pure racing skills seen in F1. I think this kind of proposal is better than push and pass or allowing the driver to dial in extra front wing a maximum of twice a lap (can you imagine the controversies that would generate - was he crossing the line, which lap does it count towards!). We want something that is organic to the racing experience. Something that drivers can learn to exploit and the spectators can intuitively grasp, like changing track conditions, to make the best drivers stand out from the rest.
Let's leave aside the scientific improbability of such a tyre compound. I want to know if it was possible what do you think the effect on the racing would be? Are there any more radical ideas out there for acheiving the same goal - more overtaking but in the racing spirit, no push and pass. We want the best driver/car combination to win.
Thanks to Tomba and the rest of the contributors to this board. I have enjoyed reading your posts for the last few months. Keep up the good work.
