That is fair enough.. ..if we go by published research articles & current production units on sale..
..but AFAIR, Honda has experimental data relating to high speed HCCI characteristics going back to their `60s G.P. bikes..
could be the post Bahrain test changes to allow them to mix it in the midfield until the huge upgrade debut some point in mid season
Thank you Wazari to visit this forum one more time, i hope you not retire from this forum as well..Wazari wrote: ↑05 May 2017, 01:03Hi all! Since I have received some inquiries and have ignored almost all of you (sorry) I am taking the lazy route and will try and answer most of your questions in one post. I have not stayed current with this thread so if I'm repeating some things or posting something no longer relevant, I apologize in advance.
Yes I am disappointed and anticipated many issues but not to this extent. Yes the compressor is out of the "V" and in front. Yes the MGU-H is in the "V" and slightly lower than the previous PU as is the MGU-K. There were 3 combustion process designs decided upon and with strong advice from outside consultants this current spec was built. The next spec will be "our team's" process/design which obviously I am biased towards. All 3 concepts/designs were "in-house" designs. Just to clarify Honda is not opposed to "outside" help and consultants; it is welcomed. Getting outside help is another matter. A new head, pistons are supposed to be implemented soon.
Yes I am enjoying retirement again. I am mentally at peace. I was asked if I would consider working in the UK for 10 months and I thought about it for 5 seconds and then got mad at myself for wasting 5 seconds.
Food for thought: What if the new PU was expected to run at 1,500 RPM's on average higher than the competition and was actually designed to be more efficient at the higher RPM's? What if??? However certain vibration issues occurred at the higher RPM's??? Just speculation.........of course. Think about the extremely high CR and its relationship to RPM's. Also would you rather have your ICE powering your turbine/MGU-H at 10,500 or 12,250 RPM's if the consumption rate was the same? Just thinking while typing.
Again thanks for all your inquiries. I am fine and enjoying life. The season isn't over and I'm still optimistic for a big turn around Silverstone/SPA.
Are you new here?Anony Mous Engineerd wrote: ↑03 May 2017, 20:19rumors, nothing but rumors based on slightly odd engine noises compared to some other cars.......ENGINE TUNER wrote: ↑03 May 2017, 20:10Is it a proven fact that they are using "alternative firing orders"? Or is that just some alternative facts that have been thrown about around here?
There are a few things. Camshaft timing is one, especially if a pre-chamber is used then I suspect that camshaft timing may be critical to get proper filling of the prechamber.Singabule wrote: ↑05 May 2017, 01:33Thank you Wazari to visit this forum one more time, i hope you not retire from this forum as well..Wazari wrote: ↑05 May 2017, 01:03Hi all! Since I have received some inquiries and have ignored almost all of you (sorry) I am taking the lazy route and will try and answer most of your questions in one post. I have not stayed current with this thread so if I'm repeating some things or posting something no longer relevant, I apologize in advance.
Again thanks for all your inquiries. I am fine and enjoying life. The season isn't over and I'm still optimistic for a big turn around Silverstone/SPA.. Compression is limited to 1:18, and honda's higher rpm should waste more energy through parasitic loss and Compression loss. I cant imagine how to archive better efficiency at higher rpm unless boost is limited by regulation too. At extremely high rpm, easier to minimize detonation, so at lower rpm honda engine is always at big risk of detonation, and lower boost is expected to mitigate such risk. However, this also lead to peaky nature of power delivery and bad to drivability so MCL slide everywhere. The Deployment from K is not perfect too, because of unmatured software because of Last minute engine Development. Pretty big task from honda to improve drivability imo than outright power.
