But given T12 is 100% throttle, how could Red Bull be limited by it's chassis? Only if they had more drag, which I don't think was the case. Mercedes had advantage on Turn 7 because it's the flat-out exit of T6, so that's why RB13 and Haas couldn't keep up, imo.Nuvolari wrote: ↑10 May 2017, 12:25You're right that turn 12 is full throttle, and I would disagree it's all about power...I think the plot above illustrates that it's not. If it was only about power, the acceleration through turn 12 would be closer to the dashed line. The respective delta between the dashed line and the unbroken lines, indicate how much the cornering speeds were limited by the chassis. The Mercedes is carrying a lot more speed through turn 12 because it is less limited by the corner, than the RB or Haas.
The delta between Mercedes and RB/Haas at T12 apex (6 km/h), is bigger than the delta between them simply accelerating along the straight full throttle (5 km/h). In any case, all cars are so far from their ideal straight line accleration speed, that if RB was producing more or less equal downforce at high speed to Mercedes, there should be no problem with matching Mercedes through there. Happy to be corrected.
Grosjean was also matching the Mercedes through turn 6. It's Turn 7 where both RB and Haas lose to Mercedes. This is consistent with the turn 12 data. The one aspect of RB13's performance that lifts it clear of the midfield cars is low speed cornering.
PR nonsense. New FIA rule is, the car has to show full driver name or 3 letter shortcut AND driver number from each side.
OK, but I think you answered it yourself.
Let's not forget that Ferrari run with high rake; clearly running with high rake this season doesn't prevent you from being fast.SparkyAMG wrote: ↑09 May 2017, 18:10Continuing the off-topic theme, Mercedes stated that they explored switching to the high rake concept for 2017 but found its potential to be limited compared with the long wheelbase concept they opted for.adrianjordan wrote: ↑09 May 2017, 16:05I know this is off topic, but if the new rules have destroyed their concept of high rake etc, then I wonder if that has impacted on Mclaren as well...TNTHead wrote: ↑09 May 2017, 13:09In Auto Motor und Sport a summary is given at the point Red Bull stands now
http://www.auto-motor-und-sport.de/form ... 27537.html
They state that the Barcelona update of the chassis is aimed at increasing the downforce at back of the car so they can get the rear tyres in the desired temperature range. Furthermore they question whether the new regulations have destroyed their concept (high rake, without losing too much top speed). I am curious which parts will be updated (beside confirmed base plate and front wing). They even may change their basic concept so that the b-spec can be seen as a new car.
I hope Red Bull's Barcelona package is as radical as the media would have us believe. Chucking them into the Ferrari / Mercedes mix should produce some incredible races.
I'm pretty sure Ricciardo's talking about the updated parts we'll be seeing on the car this weekend and not the liverySR71 wrote: ↑10 May 2017, 20:18Do we think Dan R means livery or is it a Mercerrari?
https://twitter.com/thebuxtonblog/statu ... 5755030528
So they have copied solutions from both teams. It could work but its rather disappointing coming from RB.Flying JPS Lotus wrote: ↑11 May 2017, 04:12I'm pretty sure Ricciardo's talking about the updated parts we'll be seeing on the car this weekend and not the liverySR71 wrote: ↑10 May 2017, 20:18Do we think Dan R means livery or is it a Mercerrari?
Interesting to see the car will remain the RB13 this weekend though we'll see if the new parts are enough to call it a genuine B-spec. And hopefully the updates are exotic and good enough to propel them to the front with Merc and Ferrari. But at this point I risk getting my hopes up again...
Not denying this fact, its only that Newey uses to bring some "original" updates.
Maybe I should give another example to illustrate my point better.Artur Craft wrote: ↑10 May 2017, 19:51But given T12 is 100% throttle, how could Red Bull be limited by it's chassis? Only if they had more drag, which I don't think was the case. Mercedes had advantage on Turn 7 because it's the flat-out exit of T6, so that's why RB13 and Haas couldn't keep up, imo.Nuvolari wrote: ↑10 May 2017, 12:25You're right that turn 12 is full throttle, and I would disagree it's all about power...I think the plot above illustrates that it's not. If it was only about power, the acceleration through turn 12 would be closer to the dashed line. The respective delta between the dashed line and the unbroken lines, indicate how much the cornering speeds were limited by the chassis. The Mercedes is carrying a lot more speed through turn 12 because it is less limited by the corner, than the RB or Haas.
I think the delta on T12 is bigger because maybe Bottas had a better exit out of the previous corner?
Bahrain's T2 and 3 are very low speed and aero drag will have no impact. What China's T7 data suggests to me is that either Mclaren has less drag than Renault(what is their gap on the speed trap?) or Honda is as good/bad as the Renault. Btw, I really think that Renault's PU is the factor holding back the Red Bull car, if they had a Mercedes or Ferrari PU, I think they would be fighting for winsNuvolari wrote: ↑11 May 2017, 15:29I've posted this here before (not the greatest alignment of the plot, but you get the idea). Alonso was matching the Renault through turn 7 in China, however the minimum speeds through the corner is in the range where the Renault PU should easily have power advantage over the Honda---given the popular wisdom that the Honda is nowhere close to the Renault PU. IMO, these data do not support the statement that a car that inherently has a power advantage would necessarily outperform another car, in a full throttle corner, whether it was a high/medium/low speed.
Another example: look at the speeds through turns 2 & 3 of the Bahrain circuit.
I appreciate that Bahrain T2/T3 drag will have less of an impact, it was an extreme example. I believe, Renault will be quicker than McLaren by about 2-3 km/h at China T7 speeds. I think I'm at the point where I recognise we are going around in circles so, according to our logic:Artur Craft wrote: ↑11 May 2017, 19:20Bahrain's T2 and 3 are very low speed and aero drag will have no impact. What China's T7 data suggests to me is that either Mclaren has less drag than Renault(what is their gap on the speed trap?) or Honda is as good/bad as the Renault. Btw, I really think that Renault's PU is the factor holding back the Red Bull car, if they had a Mercedes or Ferrari PU, I think they would be fighting for wins
