Having seen this photo, I'm inclined to agree with you. It shows a smaller rear end device than I first thought from pictures taken from the front.
![Image](https://pbs.twimg.com/media/C_kKwm7XUAUxYcv.jpg)
It is counter intuitive, but here's my view on why. In dirty air you don't loose vortices, they just don't work as expected (their strength decreases) so when you have 15 of them (as you say) all 15 of them will suffer. Some more, some less, but all will suffer. It's not like 3 will fail to work and others will be OK...
I imagine it sends quite a strong vortex towards the floor. The 'issue' with this is that it isn't an area between two panels anymore, and in that sense it doesn't 'shield' air under the chassis from possible influence from the tire.PlatinumZealot wrote: ↑12 May 2017, 02:43Ok. No im confused... What the actual hell is that thing?
It splits the air up top... Flattens the air below... While functioning as a guide vane and a vortex generator?!
It appears to create lift on it's trailng edge but i can bet it doesn't? Or maybe it does but the net benefit downstream makes up for it?!! Aw shucks someone put this thing in CFD!
This snowplow has at least 2 functions: one is to generates DF at the front axle (coz I didn`t saw any updates to the FW and increasing the AoA could rob them useful airflow that is needed at the back of the car ) and the other one is to channel this clean airflow towards the hole in floor (see the picture) which is acting like a vortex generator, in order to make a strong vortex going to the back of the car and acting like a tyre skirt ...
They are really pushing the limit of the moveable aero regulations with that one.ChrisDanger wrote: ↑12 May 2017, 11:37Another interesting one...
https://pbs.twimg.com/media/C_jHsotXoAIZPkE.jpg
#aerogollumturbof1 wrote: YOU SHALL NOT......STALLLLL!!!
Presumably that winglet is part of the ducting for the braking system (dans79 wrote: ↑12 May 2017, 11:40They are really pushing the limit of the moveable aero regulations with that one.ChrisDanger wrote: ↑12 May 2017, 11:37Another interesting one...
3.8 Aerodynamic influence
With the exception of the ducts described in Article 11.4, any specific part of the car influencing its aerodynamic performance:
a) Must comply with the rules relating to bodywork.
b) Must be rigidly secured to the entirely sprung part of the car (rigidly secured means not having any degree of freedom).
