MrPotatoHead wrote: β20 May 2017, 19:46
Sasha wrote: β20 May 2017, 19:40
One of the persons who designed the new CC/heads/pistons stated it would take about 4 months.(stated in late Feb)
July? after Summer Break?
And that timeframe is only if there is no major problems.
Also the vibrations are like a Godzilla running in the building!
If the design work is done it should not take that long.
They should be aiming for half of that.
They didn't fully understand the engine they placed their focus upon to bring to the track. If they did not fully understand that engine or it's problems, then clearly they are going to know a lot less about their secondary concepts, as it appears that these concepts only made it to single cylinder testing before choosing the concept to move forward with. Either way you look at it, there is a level of naivete. Either now, or back then. Personally, it seems to me that they are doing the work now that they should have done prior to the seasons start, and ensuring that the design is fully developed and tested before bringing it to the track.
They will always look like a joke, right up until the moment that they don't. It sounds like a stupid thing to say, but the moment Mclaren and Honda starting knocking on 6th place more than just out of luck, then the half empty glass will be half full, in a heartbeat. Perceptions change fast in this sport.
I also think that it will be easier for people to accept an engine to appear later that delivers the goods, than for an engine to appear a little earlier that still needs some work to look respectable, even if they start performing at the same level at the same time. Otherwise it is another engine that doesn't work and a further perceived setback. I'd imagine that would also affect Alonso too, that if the update came and broke down or didn't quite perform, even if two races later it was up to scratch, the final nail might in the coffin for his contract renewal.
This is my speculation but they have to draw a line under the seasons start, and moving forward, they have to get it right, first time and every time. That, for me, will be progress.
