I am so curious about the new software and the new mesh settings.
I simply cannot wait any longer...
The launch of your cars is the best without any doubt =D>
Code: Select all
C:\Program Files (x86)\ESI\OpenFOAM\1606>"C:\Program Files (x86)\ESI\OpenFOAM\1606\Windows\Scripts\of_start_container.exe" -Arguments "C:\Program Files\Docker Toolbox\;C:\Program Files\Git\bin"
Starting "default"...
Machine "default" is already running.
Error checking TLS connection: Error checking and/or regenerating the certs: There was an error validating certificates for host "192.168.99.100:2376": open C:\Users\Amministratore\.docker\machine\machines\default\server.pem: Impossibile trovare il file specificato.
You can attempt to regenerate them using 'docker-machine regenerate-certs [name]'.
Be advised that this will trigger a Docker daemon restart which will stop running containers.
An error occurred trying to connect: Post http://%2F%2F.%2Fpipe%2Fdocker_engine/v1.23/containers/of_plus_1606/start: open //./pipe/docker_engine: Impossibile trovare il file specificato.
Error: failed to start containers: of_plus_1606
An error occurred trying to connect: Post http://%2F%2F.%2Fpipe%2Fdocker_engine/v1.23/containers/of_plus_1606/exec: open //./pipe/docker_engine: Impossibile trovare il file specificato.
Stopping "default"...
Thanks, you are too kindCAEdevice wrote: ↑16 May 2017, 15:34The launch of your cars is the best without any doubt =D>
I would also welcome more time between races
