Graining? looks like that.roon wrote: ↑10 Mar 2017, 01:24Is there a term for the circumferential bead of rubber that builds up on the tire during cornering?
https://s9.postimg.org/o90tjip7j/image.jpg
https://s9.postimg.org/ub8ga0dnj/image.jpg
I would call it blistering or forming of blisters. It is locally too hot rubber that results in the surface of the tire bursting open (blistering). So it is not a bead of rubber. But this dark strip is characteristic for this phenomenon.F1NAC wrote: ↑07 Apr 2017, 22:18Graining? looks like that.roon wrote: ↑10 Mar 2017, 01:24Is there a term for the circumferential bead of rubber that builds up on the tire during cornering?
Way more sense than bringing them for Spa
I think you are correct. The backup compounds had more degradation designed in.ENGINE TUNER wrote: ↑22 Jun 2017, 20:28I think the back ups were not softer but had more thermal deg built in, not %100 sure though
That's certainly very dramatic footage but it's hard to know how to compare that to any previous era. We have had, in the past, occasional slo-mos of transverse vibrations in slow corners and the notorious Michelin standing waves from Indy.DaveW wrote: ↑03 Sep 2017, 10:37Might this be something to do with F1's problems? The image is an animated GIF, better viewed at 200% on my computer, recorded at Spa Q1, I think. The instability, affecting the whole structure, was probably caused by kerbs, but tyres were clear of kerbs in the recording.
Your comments, please....
