Sounds too simplyfied for my taste. And IF they stay with the V6 config, at least I hope they'll change the bank angle from 90º to 60º for no technical reason what so ever, but purely for the sound
Because it is for low speed engines?godlameroso wrote: ↑05 Jul 2017, 17:17If they want to spruce up the technology, why not make RCCI engines, as that has real promise, and could be very road relevant.
https://www.youtube.com/watch?v=4J7yRVT-8wk
https://energy.gov/sites/prod/files/201 ... _reitz.pdf
Who says they're not aiming at a combination of a small and a large turbo, or even variable geometry turbos to make up for the lag?Holm86 wrote: ↑23 Jun 2017, 11:48Not a fan of limiting the boost, unlimited boost is a great way to compensate for altitude diffirences of the different tracks. They should rather set the max fuel flow rate at 15.000 rpm instead.
Even though the MGU-H is an amazing piece of tech, and makes these engine very efficient, they should ditch it in favor of twin turbos. Allow the MGU-K to harvest more than 120kw, but only release 120kw to compensate for the lack of MGU-H. Even let the MGU-K harvest under acceleration, except in 1-2. gear, to prevent using it for traction control. Increase the displacement to 2000cc so the turbos does not need to be so big (laggy) when there is no MGU-H to help them spin up. Maybe open up the the regulations in the crank area, to allow split throws.
Other than that, just keep the V6 high pressure direct injection platform.
Steven wrote: ↑06 Jul 2017, 13:36Who says they're not aiming at a combination of a small and a large turbo, or even variable geometry turbos to make up for the lag?Holm86 wrote: ↑23 Jun 2017, 11:48Not a fan of limiting the boost, unlimited boost is a great way to compensate for altitude diffirences of the different tracks. They should rather set the max fuel flow rate at 15.000 rpm instead.
Or, power from the MGU-K could be used to spin up the turbos?
But I guess then we end up with similar complex power units as we already have them...
I was suggesting to add a small electric motor that could spin the turbo with battery power (without the ability to extract power from the turbo, like on the current MGU-H).Holm86 wrote: ↑06 Jul 2017, 14:04How would the MGU-K spin the turbo's?
VGT could be a possibility, and I also think they should allow a hot-vee configuration, which I dont even get why is illegal today.
But running an asymmetric setup with one large turbo on one bank, and a smaller on the other, I dont see happening.
But even though theres two turbo's they still need to be rather big to provide the around 3 bars of boost needed.
I guarantee they will not use a flat fuel-flow rate. This would lead to roughly constant-power engines and therefore single-gear driving. This can be a very effective and cheap way to go fast, but it lacks the traditional ramp-up step-down sound of the engine as it accelerates through the gears, and this traditional sound is considered an absolute must in F1 circles. The new regs will continue with a variable fuel-flow limit that's a function of rpm, and a minimum number of gears.
It would all be possible, but also somewhat complex. Im pretty sure, if they go twin turbo, they will be equal in size, with no electronic help.Steven wrote: ↑06 Jul 2017, 23:28I was suggesting to add a small electric motor that could spin the turbo with battery power (without the ability to extract power from the turbo, like on the current MGU-H).Holm86 wrote: ↑06 Jul 2017, 14:04How would the MGU-K spin the turbo's?
Also, as for the turbo, I also believe it's highly unlikely to have unequal turbos on either cylinder bank, but can't they consider sequential turbos, or perhaps a design where each bank's exhaust pipe merges, and then splits into two for the seperately sized turbos?
But again, as said, I guess this would all make things more complicated than they seem to want.
Moving the point of the max flow rate higher up the RPM scale would make the engines rev higher for sure. And I see why they created the flat rate from 10.500 to 15.000, so the penalty of having fixed gear ratios wouldnt be too big. It's pretty clever, but unfortunatly its designed for drivability, as if it was a roadcar engine, and not a race engine.
One downside to a hot-vee in this context would be the higher placement of the exhaust manifold mass. I assume F1's inconel headers are significantly heavier than their CF intake manifolds. That said, the variable intake mechanisms do add some weight beyond plain CF manifolds.Steven wrote: ↑06 Jul 2017, 13:36Who says they're not aiming at a combination of a small and a large turbo, or even variable geometry turbos to make up for the lag?Holm86 wrote: ↑23 Jun 2017, 11:48Not a fan of limiting the boost, unlimited boost is a great way to compensate for altitude diffirences of the different tracks. They should rather set the max fuel flow rate at 15.000 rpm instead.
