Mercedes AMG F1 W08 EQ Power +
Re: Mercedes AMG F1 W08 EQ Power +
Is that mini 2016 style bargeboard in front of the main bargeboard new?
godlameroso wrote:
13 Jul 2017, 16:54
I don't think so. They had it in Austria.
Thanks.
Via AMuS
ClarkBT11
Can't quite make it out, the flap on the edge of the floor looks a different shape.
We won't see any updates till tomorrow if there are going to bring any at all.
atanatizante
115
1. I don`t understand which is the reason/are the reasons behind having a horizontal lower position for the rear brake caliper and at the front brake they have an opposite one with a vertical caliper ...
2. Brake discs has 4 drill holes ... maybe they expect the rain? or just cooler track conditions? ...
3. That middle barge-board (with that lower elongated and twisted shape arm) is new? this twisted arm could act as a vortex generator?
Jesus
ScrewCaptain27
577
Via FormulaPassion.itImage
- Serj Tankian
F1Krof
94
Spot anything new for British GP?
Wroom wroom
ME4ME
79
Just for the sake of posting a stunning picture:
Source F1fanatic.co.uk
Steven
Owner
atanatizante wrote:
14 Jul 2017, 12:15
The front brakes do more work, and hence need more cooling. As such, the front brake caliper is positioned such that it is optimal for braking performance. Positioning it at the rear gives the better airflow onto it through the brake duct.
At the rear, there is much less need of cooling (due to energy recovery and weight transfer). Therefore, they can push further with optimising towards other targets, and in this case, it's the optimum for lower CofG of the unsprung mass.
The secret of Mercedes and the third element ?
http://www.newsf1.it/the-secret-of-merc ... d-element/
Moose
Moose
52
zioture wrote:
16 Jul 2017, 12:51
That entire article is just wild speculation, and not very good wild speculation at that.
Hey Lewis, you're following another car and temps are rising - back off. CLEARLY THEY'RE HEATING THEIR SUSPENSION OIL!
No... Instead, it's been a thing for decades in F1 that the cars engines, cooling systems, brakes, transmissions etc all run in very narrowly defined, tuned windows, and there have been radio messages about cooling the car since long ago.
sosic2121
sosic2121
zioture wrote:
16 Jul 2017, 12:51
Thank you for your link.
What's the thing with negative marks?!
AMG.Tzan
44
Is it me or has the Mercedes started using a bit more rake?? I think the two main reasons they got on top of their early seasons problems, are weight saving and understanding the tyres! Now they are able to win with whatever tyre compound in whatever track it seems!
