![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
LOL....better get it at winter test 2018
could also be that they are pushing the envelope like its never been pushed before!PlatinumZealot wrote: ↑15 Jul 2017, 22:44Japanese are known for great bearing technologies. It's ironic Honda has succumbed to so many bearing issues over this year alone. Premature wear of the MGUH bearings was the last issue. Could be improper bearing selection more than a design fault in the housing. They simply changed the bearings out to better ones.
I would agree with that if it was like the indycar engine which is fast and before they found out the solution had reliability issues because of "pushing the envelope". In the F1 PU, however, it's neither fast nor reliable so I dont get pushing the envelope argument at all.Macklaren wrote: ↑15 Jul 2017, 23:23could also be that they are pushing the envelope like its never been pushed before!PlatinumZealot wrote: ↑15 Jul 2017, 22:44Japanese are known for great bearing technologies. It's ironic Honda has succumbed to so many bearing issues over this year alone. Premature wear of the MGUH bearings was the last issue. Could be improper bearing selection more than a design fault in the housing. They simply changed the bearings out to better ones.
It will be interesting to see if both Alonso and Vandoorne are required to save fuel during the race. As per Wazari-sans comments, spec 3 is more about improvement in combustion efficiency rather than increase in peak output.GhostF1 wrote: ↑16 Jul 2017, 00:55I think we are just seeing solid incremental improvements with the new spec PU. Hasegawa said they are making progress with the mapping in the new engine with each outing and each GP. So every little bit helps. They're showing good pace at Silverstone, I thought they'd struggle pretty badly.
Not entirely surprised. It was an old unit with a "fix" applied to it that apparently didn't cause penalty... It stunk of issues from the get go.
Much better the consumption in this race, this is a step forwardAlonso: "The petrol pump is the official version, it made us lose power" (Movistar)
4th fastest, despite Renault, RBR, Mercedes and Ferrari all being ahead here, it was one race and they need a massive step. 4th fastest with a car that fails to finish every other race isn't 4th fastest. You're 4th fastest when you can finish the year as 4th fastest car, not when average over a season is 7th fastest because you are 4th in some races and dead last in others because you can't finish. Silverstone probably has more time on throttle in corners than most rather than all on straights so Silverstone isn't nearly as bad as people think it is for Mclaren/Honda.
