I would've thought that they used to lift completely. I don't recall any braking in recent years. But quite a big lift.
One other thing is that the racing line going into the corner had a bump that just loved unsettling the car. Is it gone with the repave ? Even so I think they'll be hard pressed to go full throttle thru that corner.
Edit:
my bad. A touch of braking going into the corner in 2015, if the graphic is to be believed.
And the same in 2016 (again, if the graphic is to be believed.) I recall also from iracing that you had to brake a little before arriving the corner with the FW 31.
