Well, if it installed properly, you should have in the
Start menu the program
hMailServer Administrator. Click on it, you'll see a
Connect dialog, double click on the
localhost host name, it'll ask you for the main password (the one you gave while installing). This is your control panel.
First, create your domain:
Click
Add domain and enter
RayRulesForever.com or something like that
as domain name, click
Save.
Second, create one account:
Expand the
Domains Name tree to the left, click on the domain
RayRulesForever.com you've created, click on
Add Account, enter
ILoveRay as name of the account, set the password. You've just created the adress
ILoveRay@RayRulesForever.com.
Now, tell HMailServer your PC public name. You have to specify the public hostname of your computer or some other mail servers will reject your mail.
To do this, go to the tree to the left again and click on
Settings -> Protocols -> SMTP. Click on the
Delivery of e-Mail tab. Under hostname, enter the public name of your computer in the Internet. It should be something like
mail.RayRulesForever.com, but you have to know which name you specified when you installed your Internet Server (I think, I'm not sure about this, can somebody help here?).
You're almost there, but now you have to "specify your SMTP relayer": some ISPs will block the port 25, in that case you need to convince the server of your ISP (your cable or Internet company) to open it for you. So:
Go to Start/Run and type
cmd to start a command screen. Type
telnet mail.hmailserver.com. If you can connect, your port 25 is open, if you can't the port is blocked. Normally, you should be able, but if you aren't then:
Go again to
Settings -> Protocols -> SMTP and click on the same
Delivery of e-mail tab. In the
SMTP Relayer box enter the host name of your ISP mail server (you'll have to ask for it or you could check the headings of your e-mails, or you could use a small DOS program called
tracert to find it, I hope you don't need that last option
That's it, I think.
BTW, you're not "creating a website", you're only creating a domain and, inside it, mail accounts that people can check using their mail program.
A final comment: I find hard for you to be able to avoid spammers, other mighty people has failed at that. There is a large chance of your machine being used by others for spam.
