Mercedes AMG F1 W08 EQ Power +
e30ernest
e30ernest
27
Re: Mercedes AMG F1 W08 EQ Power +
Just_a_fan wrote:
01 Sep 2017, 21:00
The foam would be an easy way to customise the feel for the individual driver.One might want to feel a stiffer response to the pull on the paddle, for example. Different foams would give different resistances and would be lighter and simpler to change than a spring within the mechanism. It might just be to stop vibrations giving spurious feelings too.
I wonder if it's just there as a dampener for vibrations more than anything else.
De Jokke
Does anyone knows why merc runs the 0.9 engine (already at spa) while they're entitled to the 1.2 version ?
Mercedes AMG + Hamilton => dreamteam!
If you can't beat'em, call Masi!
Maybe 0.9 is what the engine prefers. Too much oil can't be good for it is a posion in the fuel. Probably reduce engine life, varnish the parts or something like that.
carisi2k
De Jokke wrote:
03 Sep 2017, 02:57
Apparently because there was a gentlemans agreement not to introduce a new engine at Spa and to overcome this Mercedes agreed to meet the 0.9 rule at Spa.
F1NAC
169
Who said that they're running 0.9? It seems odd to me. Especially early switch to new PU
SiLo
138
Toto did. Although I believe they did that so that if they need to, they can absolutely run at the higher limit to beat Ferrari.
Felipe Baby!
Tubas
Tubas
SiLo wrote:
03 Sep 2017, 20:26
I wonder if it was turned up today in order to turn the screw on Ferrari in the heartland of Monza?
i70q7m7ghw
i70q7m7ghw
49
Coefficient wrote:
01 Sep 2017, 14:13
Jolle wrote:
31 Aug 2017, 19:05
Morteza wrote:
31 Aug 2017, 18:07
The rest of the flaps are in the car :mrgreen:
https://pbs.twimg.com/media/DIj2bBPXoAEuxSL.jpg
Wonderful to see that they are using a simple piece of foam as a spring/center gizmo on the shifting paddles.
It probably helps achieve a more analogue feel to it's operation too.
The push buttons (the little silver nipples) would most likely return the paddle to center, the foam is most likely there to and prevent knocking and rattling.
hardingfv32
hardingfv32
35
How is the steering wheel secure/locked to the steering shaft?
I think I see a large C-clip like blade but it does not seem tethered.
Brian
belldanndy
belldanndy
hardingfv32 wrote:
04 Sep 2017, 19:34
Brian
They all use Quick Release for many years.
Duke
As demostrated here from years ago - https://www.youtube.com/watch?v=IxiV5WPCyLU
hardingfv32
hardingfv32
35
Yes.. but how does it work? How is the release mechanism designed to function?
Brian
scarbs
scarbs
393
The steering wheel is splined to the end of the steering column, this keeps the two aligned. the release mechanism has ball bearings pushed into a groove in steering column by springs, this secures the wheel to the column.
When the release collar is pulled towards the driver, the bearings are disengaged and the wheel can be removed.
Bill_Kar
Bill_Kar
Apparently Merc will introduce some upgrades to improve high-downforce performance, but Bottas says only after Singapore. It occurs to me that when they are giving interviews they are really confident for the Championship battle, like OK we know we will suffer in Singapore, but after that it's spot on.
dans79
267
Bill_Kar wrote:
08 Sep 2017, 17:23
It would not surprise me to see the updates in Singapore, and that Bottas's statement was just a dummy to through people off.
201 105 104 9 9 7
