Red Bull Racing has announced a contract extension for Max Verstappen. The agreement will see the two-time Grand Prix winning Dutchman drive for Red Bull until 2020, meaning a one-year extension to his current contract.
Look them up yourself, you seem so set on proving Ricci's greatness over Max you are allowed to put in the work!
Well i know Max has only had 1 extra failure in races but its harder to find out in qualifying and just wondered if anyone knew before i started searching. If you dont ask , you dont get .
GoLandoGo
Lewis v2.0
King George has arrived.
3 for Ric then (and none in qualy?) Max is up to 6 I believe. Depending on how you count Austria (clutch failure and then taken out (together with Alonso) by Kvyat. He was actually able to keep on driving after that but his clutch kept on slipping (was able to return to pits). He was also taken out in turn one incidents a few times by sheer bad luck (imho) for example Spain more so omho then Singapore (where he could have lifted).
It would indeed be quite interesting to make an estimation on how many points would likely have been collected by both in case no bad luck had existed but otoh, many cases of points taking are also because bad luck happens to others, do we include those?
At the end the points count and Ric has them. Ric wins! Ric put in a solid season, almost no mistakes, constantly there, and after a perhaps qualy deficiency in the beginning, post beginning part of the seasonI feel the last 5/6 races Ric is also on pace again in Qualy. Although the COTA result came a little bit out of nowhere in Q3, he did pull it off and that is what counts.
Subjectively I do feel Max (when his car kept running) more often put in a result that really amazed me but yeah, that is just an opinion.
Ricciardo has maximized the opportunities that came to him, but I must say he got destroyed by Verstappen this season. At so many races Verstappen was in front when trouble struck.
He had a bad start due to an anti stall issue. The anti stall issue didnt cause him to retire. Not that the accident was his fault, you just cant say it was a mechanical breakdown. He was involved in crash number X
GoLandoGo
Lewis v2.0
Yeah horner said an anti stall issue. So once he got going he would have been fine, maybe a little trouble at the pit stops. But it didnt cause him to retire do its Max 4.3 Dan
They are equal on wins, equal on poles and dan leads the podium count 9:3
Max leads the mechanical breakdowns 4:3 and leads the driver screw ups as well
GoLandoGo
Lewis v2.0
Do we think Red bull will commit to building the team around Max now he has signed ? And will Red Bull be trying to get Daniel to sign a similar deal ?
I think Daniel bring a good portion of harmony to the team. I cant imagine Max with someone like Vettel, Perez, Alonso ect as it got pretty feisty with Sainz and Max in Toro Rosso.
GoLandoGo
Lewis v2.0
