Vasconia wrote: ↑14 Nov 2017, 13:37
Restomaniac wrote: ↑14 Nov 2017, 13:24
I said this weeks ago. This was Ferrari's best chance. In 2018 Mercedes and Red Bull don't have to design a car around a banned key part of their car. Hell Mercedes are already making noises about a rethink on car build.
Mercedes is(likely) to re-desing their car with a shorter wheelbase because it semes that their current design has almost reached its limit. They find interesting too that Ferrari´s shorter wheelbase has mad possible to build a more adaptable car.
Its a risky move fore sure, because they could fail.
If Renault makes an step forward Red Bull could have an advantage here because I guess they have begun earlier than Ferrari and Mercedes to design the 2018 car.
I think that Mercedes PU is closer to its limit than Ferrari/Renault´s PU so it will be interesting to see if they can close the gap even more.
The reason IMHO goes back to trick problem.
Both Mercedes and Red Bull had it. When it was banned Red Bull were nearer to the Ferrari ideal (shortwheel base, high rake) so although it hurt them they were able to work around it better.
Mercedes where knocked 6 yards sideways as their car was not as easily modified. That IMHO is why they cannot get a car with no trick, a long wheelbase and almost no rake to work consistently. Its also why they are looking at shortening and adding rake (just like someone said they would months ago
Like I say Ferrari caught Mercedes and Red Bull cold with that late helping hand from the FIA. I would love to have seen the faces of Messrs Wolff and Horner when that little gem appeared.
The reason it was interesting in Brazil though is because it clearly showed that when that Mercedes works it truely works it's just not consistent enough on tighter tracks. I do think that if you gave Red Bull a Mercedes or Ferrari engine in Interlagos they would have won.
