Scotracer wrote:Yes, I was thinking more at the high-speed circuits like Silverstone and Istanbul.
We will have to wait. All is a question of how much the Tyre's grip has increased vs the decrease of downforce. As you know this is not a linear relation.
It is something: (NewCf/OldCf)=(Weight08+Downforce08)/(Weight09+Downforce09)
Obviously the more the downforce in 08 the more the tyre's grip has to increase for making up the loss in 09 (since 50% of a greater amount means a greater loss).
But as i said, it is still possible to have such a tyre grip, and maybe since downforce is less in 09, tyre load sensitivity will be far better so tyre's grip should remain more consistent with speed and load.
Scotracer wrote:
I had thought about what Coulthard was refering to before he stated it and whilst speeds will be increased, wouldn't it be "safer" since it's pure mechanical grip and not aerodynamic (therefore speed dependant)? It would be more consistent performance from the tyres, rather than exponentially increasing grip. More low speed grip must be a good thing, right?
Yes that is good i think because aerodynamics are great but right now a bit too sensible on F1 cars so you loose so much grip easily.
but let's add that i think what is good is good balance between both. And i think there should be a sensitivity anyway so that cars are not "too predictable".
Scotracer wrote:
Also, I was thinking about the width of the cars. How would this affect things on the tighter tracks (such as Monaco) where over-taking is restricted anyway? I know the cars used to be 2000mm wide but I can't really remember that far back!
Well, originally and i confess, that was me who said on forums the cars were to be wider, this is because in the current regulations it is stated and it was planned, but, since some times, i see many interviews about 09 and nobody talks about it.
Patrick head said about the front wing (180cm wide) that "it almost comes to the outer edges of the tyres" so i ask myself if they will or not go to 2meters wide cars??
That said it is still possible, i'll try to ask for precisions.
If it is the case, then it is not known if the bodywork will be wider and if the suspensions will. Because it the second case, the weight/load transferts will be less so better grip again.
Scotracer wrote:
The grooved tyres are well known to be unforgiving when any excessive lateral load is applied (they don't have progressive sliding characteristics) so the cars are often really twitchy and once they let go, they let go. Will this still be a factor on slicks or will some element of slippage be possible and more importantly, controllable? It would be nice to see the cars wrestling when they reach the limit of adhesion...not just spearing off into the gravel, in a huff saying they've had enough.
Basically the structure of slicks is more flexible so yes it is both more predictable and a bit more forgiving.
Did you drive go karts? some of them have really soft slick tyres and when you overshoot the limits the karts loose grip smoothly so you slow down but progressively.
Scotracer wrote:
Another element of the grooved tyres is the graining...will this be much of a factor on the slicks or is it just compound dependant and not config dependant?
Wow this hard to say, Graining is mainly a temperature dependent effect but in principle slicks are far less prone to graining.
Scotracer wrote:
Thanks for your input, Ogami...I've been reading your posts for a long time!
my pleasure
