No you won't.techman wrote: ↑04 Jan 2018, 00:43honestly if you want to get impresive GPS data, just run max drag forget about efficiency and you will achieve it. mclaren only care about their GPS and boasting about their chassis and blaming the engine supplier. let be honest, mclaren renault will not be as efficient as a redbull with their current high drag philosophy. 2018 is the year of the truth. and if they achieve anything less than 3rd place in title chase, its a big disappoinment after so much boasting about GPS dataIt's not just McLaren that has praised their last two chassis's though so it's not coming from nowhere. AMuS has reported several times how well the car does with it's tyres and how the chassis matches up using GPS traces and rival engineers told James Allen that at the end of 2016 they felt McLaren had the 3rd best(Only because Ferrari stopped developing to be fair). Then you've got the known shortfalls of the engine but in spite of that McLaren kept finishing 7th on the traditional chassis tracks. The cars have been largely praised since Spain 2015 when Button described it as "scary" and only twice since then have the drivers had a go at it, Suzuka 2016 and Button in Brazil 2016.
If only the others knew there was such a simple way of making your chassis look great. Just pile on drag!!.
