roon
roon
412
Re: Mercedes Power Unit
It can probably be roughly calculated from known formulas, but I'm ignorant of them. The Merc compressor does look big in photos, but I think this is at least partly to do with volute design.
gruntguru wrote:
23 Dec 2015, 05:20
A better image of a compact volute. You can see that the diffuser section is contained within the volute.
http://i.imgur.com/CR46bir.jpg
gruntguru wrote:
23 Dec 2015, 03:01
riff_raff wrote:That video clearly shows a compressor housing at the front of the engine. What is especially interesting is the A/R ratio of the compressor housing. It has a very large diameter. The turbine housing is much smaller in comparison . . . .
It is difficult to judge the A/R visually. The reason the Mercedes compressor looks so big is that the diffuser is radial. Most turbocharger compressor housings are "folded (rolled)" to reduce the outside dimension. Mercedes packaging has allowed them to avoid this step. Here is a comparison of the two shapes.
http://i.imgur.com/E5m4esT.png
Zynerji wrote:
09 Jan 2018, 21:11
When Merc said that the diesel guys were involved, I immediately thought they were running a high boost diesel turbo impeller, knowing they were going to bleed off 30% to the hot outlet.
Not familiar with this. Can you post a photo? This variety of compressors has two outlets?
Zynerji
111
Zynerji wrote:
09 Jan 2018, 21:11
Theoretical, but what I envisaged was happening the entire time from things that I have read, but apparently, I misunderstood the descriptions. The question is, can you run a high boost turbo (more than you can use), and pump it through a vortex tube and take the 70% that comes out the cold end and run it into the plenum without the need for an intercooler?
Jejking
Jejking
Today I read about Mercs 2018 PU: about 70 per cent new parts.
https://www.motorsport.com/f1/news/merc ... ew-993605/
This source says 'pretty much all new'.
"It's had several phase-ups through the season and we've got ideas to improve the power, the indicated power in the engine.
"We've got ideas to reduce the friction in pretty much every area of the power unit, or the losses in electrical systems." "Some of it is big, fundamental bits of learning, combustion progress, friction reduction, new materials that unlock areas where we've been struggling with reliability. And sometimes it's just a surprise.
"There's still gains to be had [with this formula]. It's a plethora of marginal gains, five millisecond gains.
"Then there's those nice surprises where you thought north would give you 2kW and actually it's south that gives you 2kW.
"It has just been about doing those great experiments and that's where the test facility is important.
"You need to think about what it is you're trying to measure but you need a very impressive dyno with incredible sensors and good test methodology to genuinely detect those gains and to pick them out from the noise of general testing."
Craigy
84
Zynerji wrote:
09 Jan 2018, 21:40
Zynerji wrote:
09 Jan 2018, 21:11
On a very basic level, would you want to use the cold output for engine intake, or would you use it to cool down the fuel or something else in the car?
I've read differing opinions on here about the fuel-limited combustion processes. There are people who think a hotter charge may in fact be more efficient, in light of the fuel flow rate limit - essentially, you're not limited by airflow (so, having cooler, denser air may not be helpful!)
Gruntguru/one of the other gurus, care to weigh in on this point?
Zynerji
111
If it was mixed at 14.7:1, I get that you would run out of fuel quickly. But mixing at 65:1 is far less fuel, even if you stuff 3 times more air into the cylinder.
It matters not, now, as with everything else in F1, they are restricting development to appease cry babies.
toraabe
toraabe
Zynerji wrote:
09 Jan 2018, 21:40
Zynerji wrote:
09 Jan 2018, 21:11
Instead of bleed they are controlling the boost by how much they are charging with the mgu-h. Known since long time...
646
@ Zynerji
an AFR of 65 ? - surely not with gasoline fuel in a spark-ignition piston engine ?
so you're saying it's SACI ?
or fuel boiled at injection ?
how would the PU be more efficient overall at a 65 AFR ?
hurril
hurril
Zynerji wrote:
09 Jan 2018, 21:40
Zynerji wrote:
09 Jan 2018, 21:11
Where would the other 30% go though?
Zynerji
111
hurril wrote:
11 Jan 2018, 23:18
Zynerji wrote:
09 Jan 2018, 21:40
Wastegate
Zynerji
111
Tommy Cookers wrote:
11 Jan 2018, 22:41
@ Zynerji
From what I've read, current engines run at 65:1 AFR in the chamber, and 14.7: only in the pre chamber.
MrPotatoHead
53
Zynerji wrote:
12 Jan 2018, 01:33
hurril wrote:
11 Jan 2018, 23:18
Zynerji wrote:
09 Jan 2018, 21:40
Wastegate
I think you are mixing up the hot and cold side. And your idea is very odd :-)
MrPotatoHead
53
Zynerji wrote:
12 Jan 2018, 01:34
11 Jan 2018, 22:41
@ Zynerji
You are reading the wrong things I think...
roon
roon
412
MrPotatoHead wrote:
12 Jan 2018, 03:29
Zynerji wrote:
12 Jan 2018, 01:34
11 Jan 2018, 22:41
@ Zynerji
What are the actual values?
MrPotatoHead
53
roon wrote:
12 Jan 2018, 03:42
MrPotatoHead wrote:
12 Jan 2018, 03:29
Zynerji wrote:
12 Jan 2018, 01:34
If I knew the actual values I wouldn't be able to tell you... but as it is I don't know for sure (but I know the ballpark) - but I know 65:1 is fantasy.
roon
roon
412
MrPotatoHead wrote:
12 Jan 2018, 03:48
roon wrote:
12 Jan 2018, 03:42
MrPotatoHead wrote:
12 Jan 2018, 03:29
What are the ballpark values?
