Re: Honda Power Unit
20 Feb 2018, 23:49
It is probably safer to control swirl by making one intake valve slightly smaller, because I am thinking that making one intake valve open slightly quicker than the other one can lead to problems on the exhaust stroke? Not to mention torsional vibrations on the camshaft. What do you think?
I think there was an VW engine that adjusted valve lift on one of the intake valves only, but I can't quite remember if both valves still closed at the same time despite that.
The valves would still close well before TDC on the compression stroke. The camshafts don't touch the valves directly, as long as there's some clearance between the rocker and valve stem any harmonics would/should be taken up by a lost motion assembly. Still I imagine you're right, that doesn't mean that they can't do both, different sized valves different lift profiles. The difference doesn't even have to be large, a few tenths of a mm difference can have big changes.
seezung
seezung
56
bonjon1979
bonjon1979
30
seezung wrote:
21 Feb 2018, 11:33
We got liftoff;
https://twitter.com/ToroRosso/status/966232170867064833
Sounds like a bag o nails again...
GhostF1
GhostF1
110
bonjon1979 wrote:
21 Feb 2018, 11:35
seezung wrote:
21 Feb 2018, 11:33
We got liftoff;
Idle sound means nothing. Honda runs the car on half cylinders in the pits before firing all 6 at exit. We don't know why they run it as such, whether it be a trick firing order or layout or just something to hide audible details from opponents. It's all speculative and has been discussed in length in this thread over the last 12-18 months.
It sounds different however, but I wouldn't mind hearing it at full chat. Here's hoping there's another tweet soon.
Squid
Squid
bonjon1979 wrote:
21 Feb 2018, 11:35
seezung wrote:
21 Feb 2018, 11:33
We got liftoff;
:roll:
It sounds perfectly normal. If you doubt it, listen to the new Ferrari engine on the Sauber:
[media]https://twitter.com/SauberF1Team/status ... 0897180672[/media]
Vladimir
Vladimir
-1
Sounds powerfull.
f1rules
f1rules
597
etusch
131
They tend to hide car until launch
nzjrs
60
Wow! that feathering of the throttle/power through gearshifts sounds quite distinctive
bonjon1979
bonjon1979
30
GhostF1 wrote:
21 Feb 2018, 11:40
bonjon1979 wrote:
21 Feb 2018, 11:35
seezung wrote:
21 Feb 2018, 11:33
We got liftoff;
Ah, thanks for that, I thought I could hear something that was different to the others. Doesn't sound too shabby while running. Also IT"S RUNNING!!!! Fingers crossed for them.
bonjon1979
bonjon1979
30
Is it me or is there a weird sound on upshift? Is it a vibration?
bonjon1979
bonjon1979
30
bonjon1979 wrote:
21 Feb 2018, 15:53
The mercedes upshift, is just totally clean but if you listen to the Honda, there's a kind of stuttering of the revs at each upshift. What do people make of that?
https://www.youtube.com/watch?v=4mtjC9DozXs
restless
restless
1y ago in Australia there were severe upshifting problems with the engine&transmission
bonjon1979
bonjon1979
30
restless wrote:
21 Feb 2018, 16:12
Is that what we're hearing in that video?
