paddyf1 wrote: ↑25 Feb 2018, 16:33
Manoah2u wrote: ↑24 Feb 2018, 21:08
paddyf1 wrote: ↑24 Feb 2018, 20:29
There will ave to be a camera in every halo about that area.
actually, no.
Actually yes, every halo will be fitted with a camera facing the driver, it used to be just in front of the windshield but the halo blocks that now so it will be o the halo, are you aware of the FIA`S high speed camera that faces the driver in cases of accidents?
A high-speed camera to assist with accident investigation in Formula 1 is on schedule to be introduced for the start of pre-season testing next March.
Speculation surrounding the cause of Fernando Alonso's testing accident at Barcelona earlier this year was partly fuelled by the lack of clear video footage showing what happened.
The FIA mandated the use of the camera on all cars from 2016 and tasked electronics company Magneti Marelli with producing the device.
It will be capable of recording, in milliseconds, the movements of a driver's head during the crucial moments of impact.
The device, which measures around two centimetres by eight centimetres and is not much bigger than a USB stick, will record 400 frames per second compared to the previous standard of 25fps.
It will be mounted on the top of the chassis, just in front of the row of antennas, facing the driver. The height position of the device has
