Mercedes AMG F1 W09 EQ Power+
Re: Mercedes AMG F1 W09 EQ Power+
New rear wing
Via @AlbertFabrega
krizalid1001
krizalid1001
Morteza wrote:
01 Mar 2018, 14:16
Via @AlbertFabrega
Seems like a bite of burning marks
DVB
garyjpaterson wrote:
01 Mar 2018, 14:06
DVB wrote:
01 Mar 2018, 14:04
djones wrote:
01 Mar 2018, 13:04
If they are filming it, then presumably it flexes?
No, they aren't filming the flex. Flex is easily tested in a wind tunnel.
Really, on a 60% model, which is presumably constructed with different methods and materials?
Yes, really. They downscale from the 100% model and use the same material, constructed the same way. Enough moving images to find from that. I think Red Bull made a clip of that part.
Previous years, different manufacturers were having flexing front wings at high speed. I don't think they are going to think, let just make a wing and see when it flexes. Imagine going out on your first run in FP1 and having, instead of a FW at 45°, having an FW at 20°.
djones wrote:
01 Mar 2018, 14:07
DVB wrote:
01 Mar 2018, 14:04
djones wrote:
01 Mar 2018, 13:04
Is it though?
I mean yeah to a certain extent, but they are not allowed to use full size models these days. And also the wind tunnel cannot do 150+ MPH?
Wind tunnels can go over 200mph. It's just how they are designed.
Everybody is a Ferrari fan.
McMrocks
McMrocks
32
DVB wrote:
01 Mar 2018, 14:26
The regulations mandate a maximum air speed for wind tunnel tests
krizalid1001
krizalid1001
A better view of the upgaded FW
From AMuS
bonjon1979
bonjon1979
30
McMrocks wrote:
01 Mar 2018, 14:30
DVB wrote:
01 Mar 2018, 14:26
Limited to 50 metres a second or 180 kph.
Ishwar030
Ishwar030
Mercedes Rear
DVB
McMrocks wrote:
01 Mar 2018, 14:30
DVB wrote:
01 Mar 2018, 14:26
That I didn't know. Thanks for the info!
bonjon1979 wrote:
01 Mar 2018, 14:41
McMrocks wrote:
01 Mar 2018, 14:30
DVB wrote:
01 Mar 2018, 14:26
Youre right, i stand corrected :)
F1site wrote:Wind tunnel testing is heavily restricted, both in terms of what kind of testing may be done and how long it may be done for. Scale models used may be no larger than 60 percent and speeds are limited to 50 metres per second.
Via AMuS
The other issue with trying to measure flex in a windtunnel is that even with the same construction, at 60% scale your stiffness is going to be much lower than the equivalent full-scale model - that is usually compensated for in larger pieces with steel inserts or similar, but that's much more difficult with a thin floor edge where there's no room for reinforcement an any you added would give much different bending characteristics.
You also have the added issue that you don't have the impacts, kerb strikes, etc, added to the chassis that might cause resonance issues.
You're much better of testing that stuff in simulation then checking correlation in actual testing rather than wasting wind tunnel time.
Via @F1debrief
krizalid1001
krizalid1001
Ishwar030
Ishwar030
Flow-viz testing on the rear wing (photo is from Tuesday)
Via @RacecarEngineer
paddyf1
paddyf1
Morteza wrote:
01 Mar 2018, 18:34
https://pbs.twimg.com/media/DXN1SEMXkAYMi6i.png:large
flow attachment across both rear wing elements
