Wow, didn't realise the sidepods were thís tiny. Amazing to see
Rocky wrote:We got a long way through the test programme then, so we were able to try out some things in the afternoon and we took the decision to do some shakedown tests and the result was small electrical problem. We lost an hour as we had to change the battery but it was a calculated risk and we learned something as a result.
I don't think so. The yellow line in the second picture is probably not drawn correctly because the crash structure has been removed with Photoshop so that you cannot see exactly where the inlet starts.jh199 wrote: ↑06 Mar 2018, 22:47Have they changed the sidepod inlets? They look more cashew shaped and even smaller than before
http://abload.de/img/12nsx1.jpg
https://pbs.twimg.com/media/DWY4XhjXkAASBmb.jpg:large
True, true. Now, do you think the airway tightens just inside the inlet? If you look at the newest photo, there seems to be a bulge leading toward the driver just pasted the intake inlet. I would write it off as a lighting illusion but it appears on both sides of the car. Maybe just a strange reflection from the coolers?MtthsMlw wrote: ↑07 Mar 2018, 00:00I don't think so. The yellow line in the second picture is probably not drawn correctly because the crash structure has been removed with Photoshop so that you cannot see exactly where the inlet starts.jh199 wrote: ↑06 Mar 2018, 22:47Have they changed the sidepod inlets? They look more cashew shaped and even smaller than before
