Flow separation on the sidepod behind the bargeboards or is it just the paint that’s not been applied well?
That’s a lot of separation. Compare it to wings that are actually working well:Moose wrote:
That's a wing that is... not working well.
If you are speaking about air separation, is that the blue area indicated in below image?Moose wrote: ↑09 Mar 2018, 07:05https://pbs.twimg.com/media/DXyoH7SX0AAPX01.jpg
No - the top edge of the wing. The curly mess of flowvis indicates that something like this is happeningGTR wrote: ↑10 Mar 2018, 00:19If you are speaking about air separation, is that the blue area indicated in below image?Moose wrote: ↑09 Mar 2018, 07:05https://pbs.twimg.com/media/DXyoH7SX0AAPX01.jpg
http://i63.tinypic.com/dpfnsi.jpg
Wing's working fine. DRS can cause flow separation at that point.Moose wrote: ↑09 Mar 2018, 07:05https://pbs.twimg.com/media/DXyoH7SX0AAPX01.jpg
I don't buy that - mostly because you don't see this on other team's wings, as shown above by the Mercedes flow vis.PlatinumZealot wrote: ↑10 Mar 2018, 01:09Wing's working fine. DRS can cause flow separation at that point.Moose wrote: ↑09 Mar 2018, 07:05https://pbs.twimg.com/media/DXyoH7SX0AAPX01.jpg
