similar evolution to Red Bull front wing from last couple of days.
https://pbs.twimg.com/media/DXMyUDxWAAEADNL.jpg
The Manor Racing windtunnel model had it too.
so they've tested modified exhaust (not pointing upwards)
My assumption about the lack of high-central radiators generally was that they were a risk to the driver. Hot coolant right behind the drivers neck. If ruptured, it could be exposed to the driver. Usually central radiators are a bit lower and farther back than in this Renault installation.wesley123 wrote: ↑08 Mar 2018, 13:47fairly certain that's a radiator, the hole is visible in the airbox itself, the open area is uncharacteristic of an airbox.Blackout wrote: ↑08 Mar 2018, 11:49AMuS
Is that an air filter for the compressors air or a radiator? (lower intake)
https://imgr2.auto-motor-und-sport.de/N ... 151752.jpg
A NACA style inlet at the front.
