They intruduced wider packaging in Malaysia. They put that rear rad over the gearbox there. Hence there is the reason to make bodywork wider.
Remember...
https://cdn-7.motorsport.com/images/amp ... 751600.jpg
Nice, thank you!aleks_ader wrote: ↑23 Mar 2018, 19:26They intruduced wider packaging in Malaysia. They put that rear rad over the gearbox there. Hence there is the reason to make bodywork wider.
Remember...
"In the past"?PlatinumZealot wrote: ↑17 Mar 2018, 18:59I really hate the Oil burning discussion in the engine threads. It's just speculating over the mundane and really adds no
real technical value to the engine topic.
There is nothing interesting talking about who was burning oil in the past. That belongs in general chat or something.
You are actually talking about soemthing different now. Which is not much related to the oil burning blame game arguments.J.A.W. wrote: ↑25 Mar 2018, 00:00"In the past"?PlatinumZealot wrote: ↑17 Mar 2018, 18:59I really hate the Oil burning discussion in the engine threads. It's just speculating over the mundane and really adds no
Seems not.
Q in Melbourne - clearly showed a prominent emission of misty vapours - issuing from the rear of the Ferrari,
when exiting the pit, a technical matter, to be sure..
If you were to disconnect the PCV system on any car and vent to atmo, you would see similar. the issue is larger on forced induction cars.J.A.W. wrote: ↑25 Mar 2018, 00:00"In the past"?PlatinumZealot wrote: ↑17 Mar 2018, 18:59I really hate the Oil burning discussion in the engine threads. It's just speculating over the mundane and really adds no
Seems not.
They must have oil rings. The number of them and degree of tightness is another question.johnny comelately wrote: ↑25 Mar 2018, 04:04Apologise for posting this again, but the bit of discussion was not conclusive:
1. could they be running NO oil rings?
2. what is the throttling system on the Ferrari?
3. are Ferrari using a variable intake length?
OK, Thanks for the replyPlatinumZealot wrote: ↑25 Mar 2018, 06:14They must have oil rings. The number of them and degree of tightness is another question.johnny comelately wrote: ↑25 Mar 2018, 04:04Apologise for posting this again, but the bit of discussion was not conclusive:
Throttling system is Individual like always. For quicker cylinder filling (response).
Yes using variable intake from 2015.
Doubt it..FightingHellPhish wrote: ↑25 Mar 2018, 04:06If you were to disconnect the PCV system on any car and vent to atmo, you would see similar. the issue is larger on forced induction cars.J.A.W. wrote: ↑25 Mar 2018, 00:00"In the past"?PlatinumZealot wrote: ↑17 Mar 2018, 18:59I really hate the Oil burning discussion in the engine threads. It's just speculating over the mundane and really adds no
Seems not.
exactly re black flagJ.A.W. wrote: ↑25 Mar 2018, 09:04Doubt it..FightingHellPhish wrote: ↑25 Mar 2018, 04:06If you were to disconnect the PCV system on any car and vent to atmo, you would see similar. the issue is larger on forced induction cars.
1stly, it is highly unlikely that forced induction F1 mills do not run at -ve pressure in the crankcase,
so 'blow-by' as such, which will normally be a sign of malfunctioning/worn-out internal sealing, is out..
Unless of course, it is a deliberate oil-mist consumption mechanism 'breathing' - at a low boost state..
('Blow-by' venting to the slipstream, while racing - has to be a 'probable cause' for a 'black flag' deal, no?)
How is it P-Z, you so steadfastly fail to see 'the timber for the trees' & 'where there's smoke - there's fire'?PlatinumZealot wrote: ↑25 Mar 2018, 03:53You are actually talking about soemthing different now. Which is not much related to the oil burning blame game arguments.J.A.W. wrote: ↑25 Mar 2018, 00:00"In the past"?PlatinumZealot wrote: ↑17 Mar 2018, 18:59I really hate the Oil burning discussion in the engine threads. It's just speculating over the mundane and really adds no
Seems not.
Routing the vent out back isnt really anything profound either however yes the prominent emmisions tell us Ferrari has a higher volume of particles in the blow-by gasses at low engine speeds. Why is this so? That could be a constructive discussion. Better than the wild beaten to death old burning speculation.
