I also asked that, but no reply. Were Hamilton's tires used up or still had life in them? Was he losing time to Raikonnen or was the gap holding still?digitalrurouni wrote: ↑27 Mar 2018, 14:48Ok so going with that argument I still don't get why when Kimi pitted Hamilton had to pit. If he had more than a 3 second gap from the beginning then he would not have gotten an undercut and he could have kept going for a longer stint cause he would see Vettel is still not pitting and once Ham had done a satisfactorily long stint he could have then pitted without any thread - or he could have done a Ferrari and pitted under VSC as well!ENGINE TUNER wrote: ↑26 Mar 2018, 22:17They were saving tires, not the engine, they still needed to go 40 laps on that 1 set and would have to worry about tires for any restarts after that time.digitalrurouni wrote: ↑26 Mar 2018, 17:02I agree the 3 PU rule is destroying not only the race but the weekend. In the rain it seemed more and more people were inclined to not bring their cars out during free practice so that' s horrible for fans.
And I don't understand the need for Mercedes to always run a tiny gap with the cars behind them. From what I could see Lewis could extend his gap at will. He was in the clear air, he had no traffic. A 3 second gap with 2 Ferrari's right behind you and no Bottas means they were just asking for it. Simple as that. It's utterly mind boggling an outfit like Mercedes would run a race with so tiny a gap. I do not believe that they did not have pace in their car to have extended to at least 5 seconds.
I still think it doesn't make sense that they are allowed to race in the pit entry and exit.JasonF1 wrote: ↑27 Mar 2018, 18:34Here is my take on what happened with the Mercedes software blunder:
Lewis was 11.7s behind Vettel just before the VSC appeared, however that jumped to 16.2s JUST BEFORE Vettel pit. This time jump is due to the fact that the VSC maintain the distance delta between two drivers and not the time delta (Before the last race, I thought the VSC maintained the time delta so I was surprised when the time delta jumped from 11.7s to 16.2s). Once Vettel rejoined the track, he was about 1s in front of Lewis. Mercedes said they needed Lewis to be less than 15s behind Vettel in order to be safe. As such, they thought he had a 3s margin.
Considering the above numbers, it can be said that Mercedes were correct in their assessment that Vettel would lose 15s while pitting under VSC (16s-15s=1s) and correctly accounted for the fact that the speed was unlimited on pit entry & exit. What they completely missed was that the activation of the VSC would INCREASE the time delta between Lewis and Vettel (from 11.7s to 16.2s).
So the group who coded the program did a massive and costly oversight and forgot to include that parameter. What they were seeing was the safe margin under VSC but NOT the safe margin under normal racing conditions. If properly coded, the software should have displayed that Lewis needed to be less than 10s-11s behind Vettel in order to be safe.
Hamilton has said he still had life in them , the only reason they pit him was to cover themselves from an undercut from Kimi.komninosm wrote: ↑31 Mar 2018, 00:35I also asked that, but no reply. Were Hamilton's tires used up or still had life in them? Was he losing time to Raikonnen or was the gap holding still?digitalrurouni wrote: ↑27 Mar 2018, 14:48Ok so going with that argument I still don't get why when Kimi pitted Hamilton had to pit. If he had more than a 3 second gap from the beginning then he would not have gotten an undercut and he could have kept going for a longer stint cause he would see Vettel is still not pitting and once Ham had done a satisfactorily long stint he could have then pitted without any thread - or he could have done a Ferrari and pitted under VSC as well!ENGINE TUNER wrote: ↑26 Mar 2018, 22:17
Kimi had purple S2 so Mercedes had to play safe and pit Hamilton.JasonF1 wrote: ↑31 Mar 2018, 09:12Hamilton has said he still had life in them , the only reason they pit him was to cover themselves from an undercut from Kimi.komninosm wrote: ↑31 Mar 2018, 00:35I also asked that, but no reply. Were Hamilton's tires used up or still had life in them? Was he losing time to Raikonnen or was the gap holding still?digitalrurouni wrote: ↑27 Mar 2018, 14:48
100%, It was crazy not to pit. So Merc did the right thing, If they Tyres were still ok, it still made no sense to stay out as the new tyres were almost definitely going to be better and running to the end from that point was always pretty easy.
