Originally from what I know, they were put in to slow curves that were too fast,a la the old Hockenheim up the back, where if you would have seen Randy Mamola in 6th banging his fairing on the ground, you would agree it needed slowing down, but it was possibly too much and turned it into what was called a mickey mouse part of a track (stop/go) (except it became a very handy place to do plug chops), then at Bathurst they put in the Chase which is perfect in my opinion , no stop and turn and turn and go with virtually NO passing (except under the first braking and which often ends up in crashes) , which is my point.
here are some examples -
Circuit Gilles Villeneuve – turns 12, 13 -13m radii and 3 - 4 m between centres
Baku City Circuit turn 5 & 6 “
Spa 19, 20 – 10m rad less than 90 degrees, 20m between cs
Monza turns 1 &2 - 8,10,10
Singapore 16 through 21
Sepang 1 &2
Suzuka 16, 17
Autódromo Hermanos Rodríguez 4,5 and 13, 14
Yas Marina Circuit, take your pick
