active suspension can be realised simply by using active spring mounts
(removing from conventional suspension the effects of relatively steady forces eg aerodynamic downforce )
active spring mounts can be realised simply by ......
mechanical 'irreversibility' MI (or nearly that) or by electrical 'irreversibility' EI (or nearly that)
'irreversibility' means non-backdriveability ie the variable spring mount height behaves like a fast-acting jack
MI or near-MI works with conventional electric actuation ie electric jacking
electrical irreversibility EI can be realised from an (unusual) motive device having very uneven flux distribution
the stepper or variable reluctance principle
this can be designed to reach and easily hold any of a number of discrete positions
positions of very high flux density at which a small supply of electrical energy will hold against external 'backdriving' force
or the position selection can even be moved by electrical energy but held by permanent magnetic flux only
it's simple and cheap
it's green (could generate its own power)
so it's road-relevant
what's not to like ?
remember
a servo-hydraulic active suspension system consumes energy continuously except at steady load ie when the car is stopped
a conventional ie 'voice coil' electric active system consumes energy continuously
this system as above consumes at steady load no energy at steady load and at varying loads consumes energy intermittently
