![Image](https://imgr1.auto-motor-und-sport.de/McLaren-Formel-1-GP-China-Shanghai-12-April-2018-fotoshowBig-8f25ab93-1157992.jpg)
#aerogollumturbof1 wrote: YOU SHALL NOT......STALLLLL!!!
There are 4 additional outlet pipes. 2 are the turbo bypass outlets. The other 2? The oil breather pipes?
I only see 2 pipes. The other two "circles" seem to be the supports for those pipes, once in placetok-tokkie wrote: ↑12 Apr 2018, 10:40There are 4 additional outlet pipes. 2 are the turbo bypass outlets. The other 2? The oil breather pipes?
I think it's just the wastegate pipes not assembled yet, what you believe to be 2 additional pipes are just the bracket to hold the wastegate pipes in place. You can see the remaining of the structure ending higher than the main exhaust as it's not assembled yet.tok-tokkie wrote: ↑12 Apr 2018, 10:40There are 4 additional outlet pipes. 2 are the turbo bypass outlets. The other 2? The oil breather pipes?
Yes, I think you are correct
agreed
