FRONT END:
Outwash:
as you guys suggested, I implemented Front Wing Cascades and increased Endplate Outwash. They help a bit to turn front wheel wake away, but most of all help to reduce pressure on the rear tire. No considerable variations on front wing downforce. Brake Ducts help quite a bit too.
Suspensions:
I've also added Front Suspensions, which changed dramatically the downstream flow. While they decrease a little bit front wing performance and generate some lift, they also provide a very beneficial downwash for radiator intake, sidepods, floor and rear wing.
Front Turning Vanes:
such elements decrease pressure under the nose and help a lot turning the Y250 vortex outwards (front wheel wake management contributed too). The problem is that they do not work well together with the bargeboards.
MID WINGS:
Intake:
I've extensively redesigned this area. I've moved the radiator intake as backwads as possible to have a better control on the airflow and more design freedom with the crash structure.
Intake Slats and Sidepods:
this new sidepos design is even more aggressive than the last one. It still wants to emulate RedBull sidepod which -I think- works in two ways:
- big downwash, along the inner sections, directed to the floor
- bargeboard vortex management along the outer sections
The "slats" help to keep the flow attached on the sidepods.
Bargeboards:
I've tried a new layout compared to the last one. It has a much greater outwashing effect, which drastically reduces pressure on the the rear tire. Unfortunately, they don't have enough pressure differential to produce decent vortices. I should look for something in between the old and new layout.
REAR END:
Nothing radical here. The diffuser is starting to work more decently... The rear wing performs well, but there is some flow detachment near the trailing edge; it will be the last thing I will take care of.
Here I cannot do what you suggested me (diffuser winglets) for the moment because the level of detail would be too big (super fine mesh or super fine tuning).
Now let's introduce a couple of innovations:
The first one is a "low pressure generator". It is supposed to help with the formation of the top bargeboard vortex. It generates a low pressure field in the right place without generating lift and without disrupting the general shape of the bargeboard.
The second one is a "channel" placed underneath the side crash structure. It is designed to follow the path of the top bargeboard vortex, taking maximum advantage of its low pressure field.
I tried similar setups but I think something went wrong (probably with the mesh). I'll do better researches in the future.jjn9128 wrote: ↑10 Apr 2018, 00:36That's quite high. Especially at the front, for the rear maybe that's fine. I'd tend to baseline FR25 RR50, depending on wheelbase it'll be about 1/2deg nose down with the splitter 10-15mm off the ground, but that's dependant on the overall philosophy - high rake vs low.
You will never have me! I really like the blue-white-red and simmetrical scheme.
I'm will impose an inlet BC on the engine intake and simulate the radiator with duct and porous medium. But only in the future...
Yeah, I knew about the Perrin project and I really like it. But, honestly, if I had to design a basic F1 car (low AoA front wing, teardrop sidepods,...) I have the sensation that I would perform just as well (yeah...I'm so humble )
