2018 McLaren F1 Team - Renault
M840TR
M840TR
315
Re: 2018 McLaren F1 Team - Renault
Andres125sx wrote:
14 May 2018, 09:21
I really think the step forward this upgrade brought was smaller than expected but:
1- Top speed (drag) looks solved now, pretty similar to other Renault teams
2- A new concept does need some time to extract its full potential
3- If we believe Newey words, PP is a very methodical person who makes small steps at once. EB is saying they will bring updates in next two races, so I´d say what we saw in Spain (Spain bastards, what the hell are you doing playing the catalonian anthem??? This people can´t differ between sport and politics...) was just the base, not the whole new car and we should expect similar steps forward in next GPs
Not sure the drag problem is solved because Alonso mentioned after the race (on team website race review) he couldn't get past Leclerc because they still lack speed on straights
Ground Effect
Ground Effect
There's still a long way to go, but we have to take it as progress. As they've said, this is the Australia car, so definitely they're still behind the development curve. The fact that they're bringing significant upgrades to Monaco, which is unusual for most teams (though Mclaren did last year) and also Canada, etc shows there's a push to improve. I get the feeling things may have been better for them, if not for the tyres used in Barcelona. This is F1, it will take time, but it's a respectable start.
F1NAC
170
M840TR wrote:
14 May 2018, 10:37
Andres125sx wrote:
14 May 2018, 09:21
Not sure the drag problem as solved because Alonso mentioned after the race (on team website race review) he couldn't get past Leclerc because they still lack speed on straights
Wasn't there onboard with ALO, when he overtook Leclerc, while using DRS Leclerc was actually gaining when they were side by side
M840TR
M840TR
315
F1NAC wrote:
14 May 2018, 10:47
M840TR wrote:
14 May 2018, 10:37
Andres125sx wrote:
14 May 2018, 09:21
Yes, he was pulling away; but I don't know if drs was enabled since it was VSC restart
BrunoH
BrunoH
yes, i think he started to harvest a lot sooner and started to lose a ton of speed.
Benii6
Benii6
F1NAC wrote:
14 May 2018, 10:47
M840TR wrote:
14 May 2018, 10:37
Andres125sx wrote:
14 May 2018, 09:21
He overtook Leclerc just after VSC ended. I don't think DRS is enabled so soon after.
fellowhoodlums
fellowhoodlums
Top speed still an issue. Seems to be...THE issue
http://www.f1i.com/news/303594-barcelon ... stest.html
NixHR
NixHR
BrunoH wrote:
14 May 2018, 11:46
Overtake starts at 4:27:
https://www.youtube.com/watch?v=lFjwSP4zUR8
M840TR
M840TR
315
NixHR wrote:
14 May 2018, 12:34
BrunoH wrote:
14 May 2018, 11:46
Looks like no drs then
Macklaren
Macklaren
fellowhoodlums wrote:
14 May 2018, 12:27
Eh... Not sure... depends on car setup. ALO's rank on the 4 charts are 17,15,12 and 4. Unlike HULK who is last in all but prob had a fuel issue
Planet F1:
Defiant Boullier rejects resignation calls
http://www.planetf1.com/news/defiant-bo ... ion-calls/
fellowhoodlums
fellowhoodlums
Macklaren wrote:
14 May 2018, 14:32
14 May 2018, 12:27
Of course it does but the issue is there. It's been admitted to by Boullier last month and I am sure subsequently by Alonso.
kfrantzios
kfrantzios
46
I see many people referring to Vandoorne's performance as the metric to the real McLaren one lap pace. How absurd... The best approach to determine maximum performance of the car is to take the best sectors of the fastest driver and combine them. No driver can outdrive a car... Fundamental physics...
Macklaren
Macklaren
14 May 2018, 14:57
Macklaren wrote:
14 May 2018, 14:32
14 May 2018, 12:27
Last month, yes...not sure after this update. Red Bulls only slightly above McL
Musa
Musa
hi all. I'm Din engineer from malaysia.
I think mclaren is not draggy. What makes red bull faster in straight line is due to it higher speed during corner and at the exit most probably due to lower center of gravity design approach they had (lower air intake and sidepode). Which means that they need less downforce to achieve the same stability under bracking and cornering. But off course the low cog design has its own downside which is they lost pronounce undercut under the sidepode like everyone else has. But I think they solve the issue by manipulating the vortice created by the wing on top of the sidepode to direct the high energy wind under the nose to go around the sidepode. I remember they took quite some to find tune to make the wings work. Also they had a lot of trouble with cooling as the whole packaging sit lower than the sidepode intake. I dont have any data to support my assumption. This is all come purely from observation alone.
I think mclaren might already been working on this, who knows. I really hope so being a mclaren fan. But seing the complexity of it I am not sure if they have the ressources to do it. The technical dept might have a problem trying to satisfy the requirement hence why the tim goss was removed.
