Steering suspension geometry (Caster, KPI, Scrub radius, trail) in F1 today?
Niels007007
Niels007007
Hey guys,
I know in GP2, the steering effort is quite high, and they only have limited caster (about 6 degs) and only a little bit of suspension trail. In F3, the caster is huge at about 13 degrees, and the trail is larger too. That makes the steering heavy but as the car is lighter and has less downforce than GP2, it is still humanly possible.
In F1, they have power steering, so they might be able to afford having a certain front suspension parameters outside of the 'humanly possible' values. Perhaps this might aid the car to turn in low speed, high steering lock situations by jacking some weight around. But perhaps this is not done at all..
Has anyone ever read about / heard about / seen / measured some of these properties in F1 these days?
- Caster
- Scrub radius
- Trail
- Kingpin angle
- ackerman
Cheers,
Niels
Re: Steering suspension geometry (Caster, KPI, Scrub radius, trail) in F1 today?
Anyone in the know probably signed one or two NDAs :wink: Maybe you could get a general feel of the KPI if you could see the naked upright.
roon
roon
412
Renault 2018:
ScrewCaptain27 wrote:
22 May 2018, 17:51
Front suspension with upright removed:
Via AMuS
Morteza wrote:
07 Mar 2018, 12:15
Via AMuS
