The word active is mentioned four times in the 2017 technical regulations, and referenced only in the realms of engine and electronics. As I mentioned twice before, the aero regs pertain to driver influence and movement of bodywork. Your definition of active is simplistic and not entirely relevant to the thread topic. If you can't handle simple, light questioning of your premises proffered, then it is you who should be looking for another room.
3.8 Aerodynamic influence With the exception of the ducts described in Article 11.4, any specific part of the car influencing its aerodynamic performance: a) Must comply with the rules relating to bodywork. b) Must be rigidly secured to the entirely sprung part of the car (rigidly secured means not having any degree of freedom). (Flexible or moveable bodywork with allowance for DRS.)
With the exception of the driver adjustable bodywork described in Article 3.6.8 (in addition to minimal parts solely associated with its actuation) and the ducts described in Article 11.4, any specific part of the car influencing its aerodynamic performance must remain immobile in relation to the sprung part of the car.
Any device or construction that is designed to bridge the gap between the sprung part of the car and the ground is prohibited under all circumstances. (Skirts.)
No part having an aerodynamic influence and no part of the bodywork, with the exception of the parts referred to in Articles 3.7.10, 3.7.11 and 3.7.12, may under any circumstances be located below the reference plane.
With the exception of the parts necessary for the adjustment described in Article 3.6.8, any car system, device or procedure which uses driver movement as a means of altering the aerodynamic characteristics of the car is prohibited. (F-Duct)
My annotations in bold. Active aero is not defined. A non-moving, non-driver controlled electronic device within the bodywork should be legal, as I said previously.
To the OP, one thinks that such devices could be integrated out of sight. The question is how much power would they consume, how voluminous they be, and how much would they weigh.
