How would domination be good? After 4 years you need more?PlatinumZealot wrote: β16 Jun 2018, 14:03Paul Riccard straight supposed to be perfect for testing the Spec 2 Mercedes engine. Hoping for domination.
Well they placed the bloody chicane in the middle of the Mistral straight...otherwise, yeah it was supposed to be perfect for Mercedes power.PlatinumZealot wrote: β16 Jun 2018, 14:03Paul Riccard straight supposed to be perfect for testing the Spec 2 Mercedes engine. Hoping for domination.
Yes. Is addictive. Ask the schumacher /ferrari fans!Gothrek wrote: β19 Jun 2018, 08:33How would domination be good? After 4 years you need more?PlatinumZealot wrote: β16 Jun 2018, 14:03Paul Riccard straight supposed to be perfect for testing the Spec 2 Mercedes engine. Hoping for domination.
Some fans think they are part of the team they are watching.Gothrek wrote: β19 Jun 2018, 08:33How would domination be good? After 4 years you need more?PlatinumZealot wrote: β16 Jun 2018, 14:03Paul Riccard straight supposed to be perfect for testing the Spec 2 Mercedes engine. Hoping for domination.
He's true (but it count's only if it's your team)...PlatinumZealot wrote: β19 Jun 2018, 12:57Yes. Is addictive. Ask the schumacher /ferrari fans!Gothrek wrote: β19 Jun 2018, 08:33How would domination be good? After 4 years you need more?PlatinumZealot wrote: β16 Jun 2018, 14:03Paul Riccard straight supposed to be perfect for testing the Spec 2 Mercedes engine. Hoping for domination.
If true I hope they use another spec 1. If they are able to run 8 races with only one PU for every session I think FIA will mandate 2PU for next year
If true, it hands the race Vettel...
for marketing reasons they want to win above all.
If a new Spec-1 engine is now less powerful than the Ferrari Spec-2 engine, then running a new Spec-1 will put them at a disadvantage. That helps Ferrari, and thus Vettel. Doing so for a number of races will continue to hand an advantage to Ferrari (and RedBull, of course).bill shoe wrote: β20 Jun 2018, 14:24Doesn't hand the race to Vettel. Probably means Merc runs a new spec-1 engine for a couple races, then takes a 10-place grid penalty when the spec-2 is ready for release. I still think Merc is stone-reliable and conservative with their power units. If it plays out exactly like I speculate with Merc then I still think Vettel will end up taking more powertrain penalties by end of year.
If Merc knows the replacement spec-1 engine only needs to last for ~ two races then they can run it harder, it sort-of becomes a short-duration spec-2 for purposes of power output.
Don't forget, what we are considering a spec 1 engine is the spec1 optimised for 6 races. A spec 1 that only has to last 3 races, and possibly some FP sessions, may be a different prospect all together. Longer 'party mode', use all the rev range etc.Just_a_fan wrote: β20 Jun 2018, 19:18If a new Spec-1 engine is now less powerful than the Ferrari Spec-2 engine, then running a new Spec-1 will put them at a disadvantage. That helps Ferrari, and thus Vettel. Doing so for a number of races will continue to hand an advantage to Ferrari (and RedBull, of course).bill shoe wrote: β20 Jun 2018, 14:24Doesn't hand the race to Vettel. Probably means Merc runs a new spec-1 engine for a couple races, then takes a 10-place grid penalty when the spec-2 is ready for release. I still think Merc is stone-reliable and conservative with their power units. If it plays out exactly like I speculate with Merc then I still think Vettel will end up taking more powertrain penalties by end of year.
Even assuming a new Spec-1 equipped Hamilton is able to finish second in each of those races, he is still handing a healthy points lead to his biggest rival. As others are likely to be in the mix too (both RedBull drivers for a start), a "finishing second will do for now" strategy is liable to fail, leading to a bigger points lead for Vettel. A points lead that becomes increasingly difficult to overcome as the season progresses.
(For those who dislike the focus on Vettel/Hamilton, yes, I know the season is about more than Vettel and Hamilton, but really they are currently the two most likely to take the title.)
Could you post the source of this claim? i cant find it anywhere
